Spring CAT maintenance
1 Post
Hi the honest answer is nothing provided your fuel is of a decent quality.
If you want to be thorough though pump fresh fuel back through the central barb fitting (one normally going to pump) and allow it to flush through exiting from the feed from fuel tank fitting or the normal fill feed. Its a simple reverse flush.
Check 'O' rings for wear as they do perish and if needed both Todd or myself can supply new ones.
Enjoy the season.
marcs
Enjoy the season.
marcs
