 iGyro question >
iGyro question
iGyro question
Old 04-07-2013 | 12:34 PM
Default iGyro question
Can the powerbox iGyro be used with normal servo outputs or does it only take serial data from the few types of systems listed on the website?
Old 04-07-2013 | 12:46 PM
Geoff White's Avatar
Default RE: iGyro question
Hi Harry,
The input to the igyro has to be one of the serial bus's(eg futaba sbus, spektrum, multiplex, jeti). The output can be normal servo connections or serial to go onto a SRS unit.
I am sure you have found it but there is a full manual here
http://www.powerbox-systems.com/shar...yro_en_v02.pdf
Geoff.
