 TOP CAT 1ST FLIGT >
TOP CAT 1ST FLIGT
TOP CAT 1ST FLIGT
Old 09-21-2003 | 09:29 AM
Crazy4Flight's Avatar
My Feedback: (540)
Default TOP CAT 1ST FLIGT
First flight for my TopCat. Just a whole lot of fun. Powered by a Jetcat P-80 radio JR 8103. The elevator servo had blown gears at preflight...I was lucky to have my Whiplash in the truck and barrowed a DS-8417 from it!!!
ID:	62709   Click image for larger version
ID:	62710   Click image for larger version
ID:	62711   Click image for larger version
Old 09-21-2003 | 11:46 AM
JohnVH's Avatar
My Feedback: (38)
Default RE: TOP CAT 1ST FLIGT
Way to go! What were you using for an elevator servo? I split mine and put an 8411 on each half, way overkill but there is nothing wrong with that!
Here is mine on a SLOW fly by!
Old 09-21-2003 | 12:25 PM
My Feedback: (540)
there was a DS-8231 in it seened a little "notchy" on the bench...an early warning sign. bought the air frame used and servo was good then but a bump in the truck may have taken out the gears. The P-80's ECU upraded from 4.0 to 4.9T and no problems with idle-low speed flameouts.
Old 09-21-2003 | 05:19 PM
Terry Holston's Avatar
Looks good, congratulations. Is this your first turbine?
Old 09-22-2003 | 03:54 PM
Congratulations. Looks great! Hope you have many great flights.
