Electronic Dynamic balancers?
Tryed several home built or cheap balancers...but no good results...
if you want good balancing level you must to buy a professional balancer ..also used..
i buyed shenck balancer and it is a good machine..
CA
This is what I use, great little machine. Don't skimp when buying a balancing machine. I have tried the home built machine and all of these different balancing techniques and you just don't get the same level of balancing a professional machine gets you.
http://www.balancemaster.com/Small_rotor_balancing.htm
Gary,
I can help you with this. While I'm retired from servicing, I have maintaind my Schenck balancer and will continue to do turbine balancing work and EDF rotors.
Kerry
Kerry
