Reload this Page >
Elite Aerosports Shockwave?
Old 12-01-2014, 02:44 PM
  #76
Zeeb
My Feedback: (41)
Zeeb's Avatar
Originally Posted by jetpilot
Dana is currently working on a step by step manual that will be digital.
The manual that is included is a bit rough but gets the job done! lol
I answer my phone 24-7 for any questions! lol
Scott
Shall I call about the whereabouts of my pilot, or can I just post a question here???? lol.....
Old 12-01-2014, 03:41 PM
  #77
jetpilot
My Feedback: (48)
jetpilot's Avatar
My order was placed 9/24/14!! still waiting!! he saying not much more wait. I hope!
Scott
Old 12-03-2014, 10:52 PM
  #78
rcpete347
My Feedback: (251)
rcpete347's Avatar
HI all, in the home stretch now, all servos installed, servo and equipement boards done now, just need to install wings, align wheels and balance.
Rcpete
ID:	2052049   Click image for larger version
ID:	2052050   Click image for larger version
ID:	2052051   Click image for larger version
Old 12-03-2014, 11:04 PM
  #79
dubd
dubd's Avatar
Glad to hear you're almost done. I'm just waiting for the rain to stop so I can maiden mine.
ID:	2052053   Click image for larger version
Old 12-04-2014, 08:30 AM
  #80
sc0tt
My Feedback: (61)
sc0tt's Avatar
Rcpete, I have to ask... Why all the vent holes in your nose door - function or aesthetics? I somewhat get the triple air cylinders because the tiny BVM ones don't always keep large doors fully shut.
Just curious...Scott
Name:	rcpete SW nlg door.JPG
Old 12-04-2014, 02:51 PM
  #81
bcovish
My Feedback: (8)
bcovish's Avatar
Maybe he's trying to turn the Shockwave into a giant whistle
Old 12-04-2014, 03:52 PM
  #82
rcpete347
My Feedback: (251)
rcpete347's Avatar
For Bypass air for pipe cooling.
Rcpete
Old 12-04-2014, 04:18 PM
  #83
rcpete347
My Feedback: (251)
rcpete347's Avatar
Join DateNov 2004LocationDnipropetrovsk, UKRAINEPosts254GalleryMy GalleryModelsMy ModelsRatingsMy Feedback
RE: How Many Fly Eagle Jets (FEJ) pipes have failed? 26 so far & counting
Friends,
I have made measurement of speed between an external and internal contour....
The interesting I have obtained the data!
Look drawings...
At first the distance between contours was 10mm (0.397) "speed of pass of cooled air there were 9 metres (354.33)" in a second.
But when I have increased it the size on 15 mm, speed of pass of air has increased to 21 metres (856.77) "in a second...
Difference of all - 5 mm (0.196)"
I repeat: speed of air between contours! Not in an internal pipe!
This data for the information
A lot of cooling is done, between the inner and outer pipe, (see first paragrath on the amount) and if bypass air is not introduced, then no cooling will happen, the air just does not magically appear, thus the slots in the nose door, plus a intake/opening vent on the bottom of the fuse.I guess thats why in all my jets, I have never had a issue with my pipes.
Rcpete
Old 12-04-2014, 04:43 PM
  #84
pbusa1400
pbusa1400's Avatar
Amazingly we have gotten by with not one pipe issue nor complaint of heat. There is around 80 Shockwaves out there worldwide.
Old 12-04-2014, 06:26 PM
  #85
mr_matt
My Feedback: (10)
mr_matt's Avatar
Rcpete
I usually cut a hole in the bypass, but in my experience with Bandits, enough air gets in somehow, probably from the holes in the bypass cover. It does not take much.
Old 12-04-2014, 06:48 PM
  #86
George
My Feedback: (57)
Pete,
You don't have to worry with either the Tam pipe or "stock" pipe supplied. I'm running the Tam pipe with not one cooling hole any where, no issues at all.
Also, I thought the Venturi effect at the rear of the pipe was the major contributor to pipe cooling by "pulling" air between the inner & outer pipes, not the air being "pushed" from the front.
Old 12-04-2014, 07:03 PM
  #87
rcpete347
My Feedback: (251)
rcpete347's Avatar
Typical openings for bypass air.
Rcpete
Name:	Miss America Cockpit_for site.JPG
ID:	2052263   Click image for larger version
ID:	2052264   Click image for larger version
Name:	jet at the field 028.JPG
ID:	2052265   Click image for larger version
ID:	2052266   Click image for larger version
ID:	2052267   Click image for larger version
ID:	2052268   Click image for larger version
ID:	2052269   Click image for larger version
Name:	Reza_4 for site.JPG
Old 12-04-2014, 07:16 PM
  #88
George
My Feedback: (57)
Oh, if you're meaning cooling for the rear of the fuse from the pipe, then again, I haven't experienced any problems in that area either.
I don't think anyone (or at least me) is saying it's wrong or bad, just not really necessary here, but does look a little cool. It's definitely your preference and that's all that matters in the end. You'll love the Shockwave for sure!! Good luck with the maiden and I'm sure I'll see it sometime.
Old 12-04-2014, 07:31 PM
  #89
Zeeb
My Feedback: (41)
Zeeb's Avatar
So Pablo, are you and Scott going to look into this possible issue? Mine is at my builders and I think he's going to be starting on it this month. He and his friend have lots of experience with jets including bypass setups as his friend was a rep for BVM for a long time. I'm going to be asking him what he thinks about extra cooling air for a model with a bypass setup.
Old 12-04-2014, 07:34 PM
  #90
dubd
dubd's Avatar
Seems like a solution looking for a problem. I've had a couple Ultra Bandits, BARFs, Ultra Flashes with full bypass without vents. No problems with heat.
Old 12-04-2014, 07:57 PM
  #91
smitty1001
My Feedback: (29)
smitty1001's Avatar
FWIW, my shockwave has 5 flights on it - Mammoth for power - plenty of hand checking for heat in all of the preflight and postflight stages. Runs as cool as, or cooler, than any of the other jets I've had or assisted with...
Honestly the biggest air issue I see with Petes pics are the BV valves for the retracts
Old 12-04-2014, 08:04 PM
  #92
George
My Feedback: (57)
+1
Exactly
Old 12-04-2014, 08:17 PM
  #93
jetpilot
My Feedback: (48)
jetpilot's Avatar
Our system runs very cool. no heat issues at all. we have a very large inlet area, a large bypass, and a large diameter fuselage. The tailpipe works as designed and the system is very cool. My tailpipe still looks like new after a hard season of flying with a K210!
I have had airplanes that got hot, but the Shockwave is not one of them. the only area that gets a little warm is the last 1/3 of the bypass and why we recommend heat shield to that area. Our bypass is very lightweight and heatshield protects it longevity.
I never even worry about cooling down my Shockwave. I used to use a blower on other jets I have owned to get the hot air out. Never an issue with Shockwave.
A naca duct will introduce more air, but not necessary in this application. the large inlets never struggle for air and the fuselage on the Shockwave is much larger than the jets pictured above. lots of area around turbine and tailpipe.
Our setup works perfect. no worries!
Scott
Old 12-04-2014, 08:35 PM
  #94
pbusa1400
pbusa1400's Avatar
If there was an issue we would solve it immediately. Not the case here. Pete preference was to open up holes on his now weak nose gear door. Zeeb enjoy your model and build as recommended I have countless hours flying and testing the Shockwave. I have personally have +assembled 10 in the manner we suggest.
Pablo
Old 12-04-2014, 08:39 PM
  #95
pbusa1400
pbusa1400's Avatar
Btw Pete how many flights and testing for heat did you do prior to cutting your door cheese grater style? Was there heat issues?
Old 12-04-2014, 09:05 PM
  #96
Zeeb
My Feedback: (41)
Zeeb's Avatar
Pablo
Thanks guys for answering my questions. I'm just trying to be careful here as I've not had an airplane with a bypass setup and considering the price tag, I want to get it right
Old 12-05-2014, 07:17 AM
  #97
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
Scott
I have/had airplanes that get hotter on the fuse rear area just sitting in the direct sunlight on the ramp not running than Smitty's Shockwave was running at Idle and all throttle settings on the ground., even with a tail wind. Heat is not an issue here. The Mammoth SP is a " Big Block " for sure but the air flow and by-pass design is perfect. We did heat shield the hot section of the bypass. Great airplane, a pleasure to build !! .
Danno
Old 12-05-2014, 12:01 PM
  #98
rcpete347
My Feedback: (251)
rcpete347's Avatar
HI, that's great that the Shockwave is perfect, but mine will be more perfect, see you all in Florida.
Rcpete
Old 12-05-2014, 12:46 PM
  #99
teambutter
My Feedback: (36)
Folks this all boils down to personal preference. Some folks, like Pete, tend to modify things to their liking and it isn't based on any testing but rather their instinct. No problems there. We provide a recommended build and as such, Scott's personal fleet of Shockwaves, Pablo's Shockwave and the two I have owned have NEVER had an issue. Trust that if we feel there is something to be improved on and, in the end allow us to provide a better product, we WILL do it. Until then, enjoy your "stockwaves"!
Old 12-05-2014, 01:25 PM
  #100
pbusa1400
pbusa1400's Avatar
Rcpete
we love ya Pete. See ya here. I'll bring the cheese.. lol
