 180rx startup sputter >
Old 06-29-2013 | 06:41 PM
My Feedback: (15)
Default 180rx startup sputter
Started my 180rx in my new hawk tonight. Started fine. But, it did sputter a bit with flame visible between the tailbone and bell mouth/pipe.
Am I always going to have a little flame there on startup? With the exception of the idle auto tube I am not sure there is much I can change. Numbers look good in gsu. Once it got going the idle was fine, not hunting. So I don't know that autotune will help anyway.
I am going to paint a bit more heat shield around though...
I have 0.70-75" of clearance between tailcone and bell mouth as per jetcat diagram.
Dave
Old 06-29-2013 | 06:54 PM
Default RE: 180rx startup sputter
Hi Dave.
Do you have your manual shut off valve closed when fuelling? Fuel can leak past the solenoids while fuelling and cause starting splutter.
I think its normal to get a bit of splutter. Especially on first start of the day.
My definition of splutter is short bursts of flame. Anything longer than a short burst is a fire
Paul.
Old 06-29-2013 | 07:04 PM
My Feedback: (15)
Hi
Yes fuel valve shut during fill. I also had just purged the fuel line...then had a short dry segment from the festo to the turbine (8"?).
I watched it flow gently in an start with appropriate rise in temps, similar to my 200 sx.
I will know more I guess after next start....I am running 2 cell LiMn but no trouble according to the gsu.
Dave
Old 06-30-2013 | 06:22 AM
mario tavarez14's Avatar
My Feedback: (37)
ok i went to the same problem with my 180RX in idle the engine aputter and i turn the (auto tune on)them problem fix.
Old 06-30-2013 | 11:44 AM
My Feedback: (37)
http://www.rcuniverse.com/forum/m_11409196/tm.htm
