Reload this Page >
BVM Kingcat - still good??
Old 02-13-2017, 07:18 PM
  #101
jsnipes
I think maybe this is a different airframe than he bought from me. I know he had an incident in the 2006 timeframe with the one he bought from me but not sure if replaced or repaired/repainted.
On knife edge ... just mix out the roll or pitch tendencies like you would with an aerobatic prop plane and you'll be able to hold knife edge using just rudder.
I call the Kingcat the SUV of jets ... can fly it most anywhere and it does everything quite well.
JS
Old 02-13-2017, 07:32 PM
  #102
nigefay
JS
Yes I understand this one was painted in Vegas by Kount's Customs but it followed the same design as the original and may have used some of the original parts. I will work at mixing out the roll or maybe fit a demon cortex gyro I have.
Old 02-20-2017, 07:05 PM
  #103
BlueBus320
My Feedback: (57)
Almost done ��
Here's a before & after of my glassed & painted deck.
Jay
ID:	2202021   Click image for larger version
Old 02-20-2017, 07:27 PM
  #104
AV8ATOR
AV8ATOR's Avatar
Jay, That looks really good.
Carlos
Old 02-20-2017, 07:32 PM
  #105
BlueBus320
My Feedback: (57)
Thanks Carlos
Old 02-21-2017, 11:10 AM
  #106
Zeeb
My Feedback: (41)
Zeeb's Avatar
Originally Posted by BlueBus320
Almost done ��
Jay
Nice work, sure looks a lot fancier than my KingCat.
Old 02-21-2017, 01:18 PM
  #107
BlueBus320
My Feedback: (57)
Thanks Zeeb
I always wanted a Kingcat, so figured I'd make this one perfect & keep it. We'll see how that goes..lol
Jay
Old 05-31-2017, 08:45 PM
  #108
AV8ATOR
AV8ATOR's Avatar
Well a little slow on posting the finished product. And boy, did this Bird turn out beuatiful and it flies awesome. Video was third flight. Built by pro builder Jeff Tolomeo. Next flight will use camcorder.
ID:	2218134   Click image for larger version
ID:	2218135   Click image for larger version
ID:	2218136   Click image for larger version
ID:	2218137   Click image for larger version
Old 06-01-2017, 02:42 AM
  #109
BlueBus320
My Feedback: (57)
That was the maiden/trim flight? Loved the T/O rotation, but the landing looked a bit hot to me. She flies great, Congrats!
Jay
Old 06-01-2017, 03:24 AM
  #110
Harley Condra
Here's a mod that I made on two KingCats so far...the one I rebuilt in post #50, and my own, show in this photo tutorial. I have a small lathe/mill combination machine, and am learning to use it, so I was able to make the necessary parts at home. The nose cone attachment method as designed, retains the nose cone very securely, but is not that easy to remove or re-install. I have tried many methods to retain the four Allen head cap screws over the years, like "o" dings around the screw shanks during assembly, etc., but finally decided to make a change.
The bracket on the bottom of the battery box is 6061 T-6 aluminum, and is attached to the battery box with four 4-40 screws and blind nuts. The carbon fiber shaft is a piece of a Central Hobbies pushrod, with the 4-40 titanium ends at both ends. I used Loctite on the aft end, and a set screw for safety (belt and suspenders approach) to hold the shaft in place. The nose cone registers to the forward fuselage frame on MS20426AD4-5 rivets, glued to the aft side of the frame with Aeropoxy. They replace the 4-40 screws...the aft nose cone frame has the blind nuts removed, and a #4 flat washer Zapped in place on the aft side.
The nose cone contains a 1" thick Flox/epoxy mixture at the forward end. The nose cone also has an aluminum bushing at the end to form the flat for the pitot tube (also turned from 6061T-6, and threaded 4-40 to match the CF retention shaft end. The inside of the flox mixture is countersunk to make it easier to insert the retention shaft through the nose cone. Slip the cone into position, screw the pitot tube on, and fly!
I can go into further detail if requested. The height of the nose cone tip and the bottom of the battery box from the bench is something you must measure accurately in order to position the retention shaft so it is not deflected (bent) during assembly.
ID:	2218147   Click image for larger version
ID:	2218148   Click image for larger version
ID:	2218149   Click image for larger version
ID:	2218150   Click image for larger version
ID:	2218151   Click image for larger version
ID:	2218152   Click image for larger version
Old 06-01-2017, 06:20 AM
  #111
AV8ATOR
AV8ATOR's Avatar
Harley Condra, That is a neat feature. I like your ingenuity will contact you in the future if i decide to do it. Right now just enjoying. Thanks for posting.
CP
Old 06-01-2017, 06:25 AM
  #112
AV8ATOR
AV8ATOR's Avatar
Jay
Hello Jay, I miss spoke Jeff did the maiden and the video was the third flight. "She does fly great".
CP
Old 06-01-2017, 07:50 AM
  #113
Harley Condra
Smile
CP
I will be glad to discuss it with you any time after 7:00 eastern time Mon thru Friday, any time on weekends......It is a pretty nice mod...no more dropped screws in the forward compartment!! 321-972-6094
Harley
Old 06-01-2017, 08:38 AM
  #114
AV8ATOR
AV8ATOR's Avatar
Harley
Harley Condra, I will be doing the mod in the near future. This Bird is keeper for sure I have had several offers on her to sell. What more can you say about the product that made the BVM name.
Thank you,
Carlos...
Old 06-01-2017, 09:37 AM
  #115
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
I have a functioning pitot in my nose so I can't mod it that way... but I do need to get a battery out soon. Are those 4 bolts really that hard to get out and back in?
Old 06-01-2017, 03:26 PM
  #116
Harley Condra
Smile Nose cone bolts
In order to remove the nose cone 4-40 Allen head capscrews, a long Allen wrench is almost a neccessity. I always used a long Allen ball driver from Micro Fasteners.
Standard - Micro Fasteners
I have a full set of standard .sizes, metric and "Pro Hold" ball drivers. You can't have too many tools.These ball drivers are from Bondhus, and are very high quality, and the prices are right.
When removing the screws, Murphy's Law prevails. One or more of them always drop into the nose compartment, requiring a magnet to retrieve them. I found that It can be somewhat difficult to reinstall them. They do a great job of holding the nose cone on, but if frequent removal is required, they can be a real pain in the you-know-what. Until I made this mod, I used 1" long 4-40 screws so that I had a little room between the nose cone and the fuselage to guide the bolts into the blind nuts. It's dark in there after you stick your hand into the fuselage, so a small flashlight helps.
So, the mod eliminates the screws, washers and their associated hassle.
Old 06-01-2017, 03:49 PM
  #117
AEROSHELDON
My Feedback: (99)
Thanks!
Old 06-01-2017, 04:11 PM
  #118
AEROSHELDON
My Feedback: (99)
Does anyone have to remove the long wing tube for transport? Mine is amazingly hard to remove or insert. I mean like 5 minutes of twisting and real effort....
Old 06-01-2017, 05:02 PM
  #119
AV8ATOR
AV8ATOR's Avatar
AEROSHELDON, Mine is new, tuff but nothing like what you are mentioning. Try using some polish that tends to help quite a bit. My fix was purchasing a full size van.
Old 06-01-2017, 06:49 PM
  #120
Zeeb
My Feedback: (41)
Zeeb's Avatar
Mine's a little stiff which I do not mind but what I do mind is the cotton 'pickin black aluminum oxide all over my hands after twisting it in....
Doesn't seem to matter how often you clean it, I still get black hands. If anyone has a solution to that I'm all ears.... lol
Old 06-01-2017, 07:27 PM
  #121
AEROSHELDON
My Feedback: (99)
Surgical gloves? LOL
I think I need to do some dremel work where the boom tube meets the main fuse tube.
Old 06-02-2017, 03:37 AM
  #122
Harley Condra
Smile Tight wing tube
The wing tubes are centerless ground at BVM. I had a very tight tube, and Don Smith and I put it back on the machine and removed a couple of thousands from it. It worked just fine after that.I only live 8 miles from BVM, so that was possible. Lacking the machine, you can remove the tube, and wet sand it with 400 sandpaper until it fits better. It's a tedious job, but worth the effort. Also, a brake cylinder hone can be used to enlarge the I.D.of the phenolic ftubes better fit. I have used both methods.
For transport, if extra space is required, I remove the tubes and replace them with slugs of the correct sized wooden dowels (Home Depot) allowing them to extend beyond the booms by about an inch, making the airframe much narrower than with the tubes installed. A couple of wraps of masking tape around one end of the wooden slugs will prevent them from being inserted beyond the booms.......the slugs I made are only about 6 to 8 inches long.
Old 06-02-2017, 05:30 AM
  #123
JP-1
I have found this helps, take a carboard tube sleightly smaller than the phenolic tubes, cut a slot in the cardboard tube, insert a small section of sand paper in to the slot, then work it back and forth through the phenolic tubes, rotating it as you go.( Tape over the slot to prevent the sandpaper coming out)
Check the fit regularly, you do not want to remove to much material.
Old 06-03-2017, 03:26 AM
  #124
Harley Condra
Smile
Instead of a cardboard tube, I have used a slotted wooden dowel (shown in the photo) with a strip of 80 grit cloth abrasive. I spin it in a drill motor and it removes the material very well. My brake hone is too large for the aft phenolic tubes.
Old 06-03-2017, 05:56 AM
  #125
AV8ATOR
AV8ATOR's Avatar
Harley, Is the design met for a firm fit and not a loose one? I will also be trying the Dreamworks struts to see if she handles landings and ground control any better than the stock.
CP
