Turbine tail pipe to bellmouth / thrust pipe clearance
My Feedback: (7)
I'm installing a Kingtech K140G in my latest project and the drawing at the end of the manual recommends a 20mm - 30mm gap between the tail pipe of the turbine and what would appear to be the start (wide end) of the bell mouth. The reason I'm asking is I've seen many turbine install photos here on RCU where it appears that rather than having a gap between the turbines tail pipe and the start of the bell mouth, the tailpipe of the turbine is inserted well into the bell mouth and perhaps has a 20mm - 30mm gap between the tail pipe and the small end of the bell mouth / start of the thrust tube. So far my only jet has been a Boomerang XL, which has no thrust tube so I haven't had to deal with issue before and I want to be certain I understand exactly what I need to do so I can get this correct on the first try.
Thanks for in advance..
Hi there the best position if using a bell mouth is the front edge of the bell mouth should be 12 mm from the back edge of the alli outer caseing of the turbine when we used the 20 to 30mm from the cone it caused a horrible high pitch whistle with a lot of power loss I found a tech drawing on the web of the correct set up of 12 mm and the problem was solved increase in power and whistle gone
My Feedback: (7)
I started this thread because I was concerned that I perhaps had the wrong thrust tube and it was too short for this aircraft. If positioned so the bell mouth has clearance from the tip of the turbines tail pipe then the thrust tube appears to be the correct length.
Thanks for the reply
