help futaba 14mz eurosport radio set up
![](/forum/images/badges/premium_member.png)
My Feedback: (39)
NY
I am trying to set up my CARF eurosport
DELTA wing 4 servos two in ea wing and a carnard that needs to work with the elevator only
using 14 ch rec how do I program the radio need to use ailevator model type
thanks
vinny
thanks
vinny
Vinnie, on my rafale (similar setup) I use model type V-tail, and mix the canards in on prog mix on elevator function (not on channel), activate the second servo in these mixes as well and activate and program the throws in these mixes. Also check the channel output on multi/ channel 5/6 is ail/ele
