Reload this Page >
Its Coming!!!! Skymaster 1/5 F-16 Arf Plus Pro
Old 07-06-2014, 07:48 AM
  #101
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
hyradulic retracts are more trouble then they are worth, you need to find high pressure line like stiff nylon that can sustain 300-500 psi, and then you need to find a strong enough motor to drive it, a turbine pump WILL NOT CUT IT they run at 40 PSI at best.
Old 07-06-2014, 08:06 AM
  #102
ww2birds
My Feedback: (14)
ww2birds's Avatar
Anton can confirm but I'd assume the hydraulic nose steering is "passive" .. meaning it has no pump, just a master and slave cylinder and you move the master with a servo, the hydraulics are just used to transmit the force to the steerable part of the nose gear. Presumably this is attractive when you don't want to move the entire strut as we usually do with a servo or cables at the top of the strut.
Regarding turbine pumps, I've seen pressure measurements way above 40psi on manufacturer test stands (more like 80-90) with the gear pumps used for turbines. I think if you go look at the excellent tread on hydraulic landing gear you'll see a confirmation of this plus some really nice setups. See: http://www.rcuniverse.com/forum/rc-j...-retracts.html
Dave
Old 07-06-2014, 08:38 AM
  #103
MNModels
MNModels's Avatar
Hi,
I think there are a bit of confusion here. I think it is possible that some of you have not owned a Skymaster landing gear designed by Likai. First of all, the hydraulic system you are referring too is the system with hydraulic pump. Skymaster have never used this system in any of their jets.
Skymaster have used an air driven oil fluid system - F104, with great success. I own one and have never had a leak or failure. This design was a 1st for RC. The second system we are talking about is the steering. It is closed loop oil system with a piston at top and piston at bottom. Servo move the piston and another piston move the steering pin. Also a first for RC and is used in Skymaster A4 with great success. I own one and would know. The reason we use this system is that there is no space for the servo to keep the system as close to scale as possible. Steering is smooth and a bump on the nose leg will not break a servo gear or link as the oil will take the load. These two designs will be followed by another fist for RC soon to be released....
Regards
Old 07-06-2014, 09:02 AM
  #104
muzzgail
muzzgail's Avatar
Is it a Secret Morne??
Old 07-06-2014, 09:31 AM
  #105
MNModels
MNModels's Avatar
Hi,
At this stage..yes. Under testing. It will be option available to all Skymaster jets, old and new....
Rgds
Old 07-07-2014, 05:56 PM
  #106
Craig B.
My guess is hydraulic braking system just using master cylinder. That would give more direct braking response than an air operated system.
Old 07-07-2014, 11:02 PM
  #107
dubd
dubd's Avatar
Can you elaborate on when these have been a problem for you?
Old 07-07-2014, 11:03 PM
  #108
dubd
dubd's Avatar
Hi,
Regards
i really like the air/hydraulic system in the 104. Genius! Looking forward to new developments with the F-16.
Old 07-07-2014, 11:56 PM
  #109
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
the 2 experiments I tried simply required way more pressure than air, also polyureathane tubing would burst. Unless you are dealing with small retracts, we are talking about 20lb plane hydraulics will give you a lot of problems.
You need 300 psi to drive hydraulics properly, then you need to find the correct equipment to handle this pressure. Just not worth it.
Old 07-08-2014, 01:13 AM
  #110
pilot tw
good idea for the install the all lights for F16! we will offer the lights install at factory soon!
Old 07-08-2014, 05:41 AM
  #111
FalconWings
My Feedback: (57)
FalconWings's Avatar
Agree with Disco here. Hydraulics are not meant for small scale tasks. Ask the CARF A-4 and Mig-29 owners. The lines eventually soften and deform, theres always risk of leaks. If at all I would prefere and air system with a good safety switch.
The path forward is all electric gear, period! (even for full scale )
Old 07-08-2014, 06:12 AM
  #112
Pepperpete
Pepperpete's Avatar
Absolutely agree! No matter what its STILL oil in lines that will weaken over time. Im sorry but no hydraulic system on the planet will stay leak free forever. And with a closed system like a jet...its way too much risk and a PITA if you get a leak. Add in small scale and that risk factor goes up 10x. I dont want oil of any kind running through my jet unless its turbine oil being pushed at way less PSI than something hydraulic.
Old 07-08-2014, 07:18 AM
  #113
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
yay lights!
Old 07-08-2014, 11:22 AM
  #114
smaze17
My Feedback: (60)
You still planning on bringing the 104 to BITW D?
Old 07-09-2014, 06:20 AM
  #115
dubd
dubd's Avatar
I will if I get through the checkout flights before BITW.
Old 08-12-2014, 08:50 AM
  #116
TJPro351
My Feedback: (8)
TJPro351's Avatar
Anybody have one of these ready to fly yet? Any new updates?
Old 08-12-2014, 10:52 AM
  #117
pilot tw
Hi, we starting test the F-16 1/5 in Taiwan, and we still waiting the scale LG for the F-16 1/5, the scale LG will finish on Sep , i will post more pictures and test flight video here,
Old 08-13-2014, 02:22 PM
  #118
TJPro351
My Feedback: (8)
TJPro351's Avatar
Thanks Anton, looking forward to see the pictures and the video
Old 08-25-2014, 06:02 AM
  #119
flytmates
Looks Great! Cant wait to see some video of it in action!
Old 08-25-2014, 06:54 AM
  #120
pilot tw
the F16 1/5 test flight on begin of this month, we had 6 landing , but no camera man , sorry, I will back Taiwan for test it again on next week, i hope that good weather on next week,
here are some pictures for the speed brake done!
ID:	2025698   Click image for larger version
ID:	2025699   Click image for larger version
Old 08-25-2014, 07:23 AM
  #121
flytmates
Speed brakes look great! Keep us updated on the progress! Its going to be a nice airframe! :-)
Old 08-30-2014, 06:16 AM
  #122
pilot tw
new color scheme for F-16 1/5,
Old 08-30-2014, 06:59 AM
  #123
AndyAndrews
AndyAndrews's Avatar
Maybe they can fix the stance. Most of the SM F-16 look like their tail is dragging. But I liked the ones I owned. I bet the gear price will drop when folks don't pay it.
Old 08-30-2014, 06:39 PM
  #124
pilot tw
Slat with Flap
ID:	2027270   Click image for larger version
ID:	2027271   Click image for larger version
ID:	2027272   Click image for larger version
Old 08-30-2014, 06:40 PM
  #125
pilot tw
intake!
ID:	2027275   Click image for larger version
