BVM 91 Manual needed
My Feedback: (266)
Got an old aggressor 2 with a brand new bvm91 with standard pipeready to fly
Does anybody have a copy of the old bvm 91 manual they can photograph and post?
its been along time and I remember there were very specific parameters to achive with top,mid range and idle settings
thanks!
Jake
thanks!
Jake
My Feedback: (12)
Ha Jake hope all is well. It is easy. Just idle and high. Make sure you have a needle you can adjust from transmitter. Set it to be slightly rich and while flying make sure you have a good smoke trail. Remember to use at least 22% oil 5% nitro. Call me if you have questions. Dan
My Feedback: (266)
Hi Dan
only doubt I'm having is midrange seems really fat - lots of smoke( wasted fuel/flight time)
do you know the default setting for the midrange needle( it may need to be put back to original starting point) or how to judge how rich it should be?
bottom, mid and top all transition and run fine - just seems way too rich in middle from what I remember they would run
thanks!
jake
thanks!
jake
My Feedback: (106)
PA
will scan and send the BVM 91 manual as well as the the instructions for the BVM mixture control - email me your email address - [email protected]
