NEW Aerobatic Sport Jet "Rebel" from Pirotti Models Italy
#203
My Feedback: (18)
After 5.5 super years since I assembled the Pirotti Rebel, it is time to perform some needed maintenance.
It's held up well and I really have nothing but great things to say about this model. I decided to pull the turbine to have it flashed with the latest s/w and serviced. I also intend to remove the old smoke tube and replace it with a new one. This time I intend to attach it to the motor mounts instead of using L-brackets.
On the bench
Front View
Tank View
Pipe View
Display(s) view
On the bench
Front View
Tank View
Pipe View
Display(s) view
#205
My Feedback: (18)
This is the condition of the turbine. It still looks like nice bling, even after several years in the field. I am tempted to install Jet Central's new 130 and move this one to another project. Not sure yet, definitely looking forward to getting it back to decide how best to proceed.
Last I heard it was sent to Mexico.
Front
Rear
Side top
Side bottom
Front
Rear
Side top
Side bottom
#206
My Feedback: (18)
Finally made time to reinstall the turbine and convert from Futaba to PB. Big thanks to Manny of Aeropanda & Juan of Jet Central for the excellent service and upgrading the turbine to the latest code.
Just in time for Spring!
Installed the freshly serviced turbine & redid the smoke injector tube for a cleaner fit/finish.
Slight modification to the board required as these receivers allow for sensors to each vs to RX1 only, like Futaba. Royal SRS & GPS sensor upgraded to the latest code.
Onboard Instrumentation
Remote instrumentation - Timer, battery volts (radio & RX), capacity in mAh, speed, altitude, etc...
Current, lost frames, fades and RSSI data
Turbine data
Turbine data
