Turboprop airframes?
Not sure how you TP owners normally check run your engines, I usually just give them a quick ground run in the airframe before flying but thought I would do a little bench running as this this is my first TP…but having tried to work my way up to full power while plotting engine/prop rpm I struggled to get beyond around 2/3rds power due to the combination of massive prop wash and hot exhaust gases (I was struggling to see and breath).Think I need some ski goggles and just hold my breath!
It's crazy the brutal amount of power these things produce.
Rob.
Rob.
#34
Here's a couple of scratch builds powered with the Wren 44TP, the Stik is the Bud Nosen 101" and made a great test bed. The other is a 136" span Fletcher top dresser weighing in at 23kg and flies remarkably well on the little 44TP.
http://www.youtube.com/watch?v=_hjj_uS_zM4 http://www.youtube.com/watch?v=oGNxyW2teC0
#36
I'm running a Solo 3 blade 22" ground adjustable pitch prop so the ability to fine tune the prop pitch to aircraft weight/eng output is infinately variable....expensive prop but in my opinion well worth the investment.
#37
1 Post
I have only built one TP plane for a customer and that was the HT Modellbau PC21, it was a stunning kit and looks incredible once done, I know this is no longer being made by them but have heard another kit manufacturer has picked up the moulds, if its going to be made again this is a peach.....
marcs
marcs
#38
That would be my first choice if it were available, I'm looking for jet like performance in a TP, if I had the time I would build my own sport TP as I think there is certainly a market there for one.
Finally got to run the engine at full power yesterday and was getting 6k static on a Beila 3 blade 24x12 which I expect will unload up to 7k in the air.
Rob.
Rob.
#39
#40
this is my project: http://www.rcuniverse.com/forum/rc-j...-spt-15rx.html
The SPT15 is quite impressive.. static thrust about 60kg with 30x16 4 blade Solo prop
picture 2 is the SPT10 vs the SPT15
#41
Around 8 years ago Air Trade made me this TR. Its been "nearly" ready for about 5 years, well finally had to finish it for a new owner. One off paint was done at the factory before they closed. Its a big airframe, but very light so SPT-5 will be ample, there are rumors of the moulds appearing again, a strengthened version for the SPT-10 would be awesome!
