Anybody got a good RAM750 pump laying around?
My Feedback: (24)
That's different than the one I've got, but essentially correct. Different fittings, etc. What did that come off of?
I actually developed a pretty good method of repair and validated the pump works again, however thinking I will need a spare.
Any other manufacture pump can work. soldering on that small piece of connector could break off during flight causing a flameout. I did the same repair on the starting motor and every so often it would break off unless you remove the brush assembly and solder from there.
Good luck
http://www.dreamworksrc.com/catalog/...0020-Fuel-Pump
Good luck
My Feedback: (24)
Soldering to the connector without much to grab onto was my single biggest concern. So, I used a jeweler's loop, x-acto knife and number 58 drill bit to dig down into the insulator carefully, exposing about 1/16th an inch of tab and drill a hole through the conductor tab. I then flowed solder through the tab and re-soldered the wire in. When assembled, it pulled very strong. I then heat-shrinked the power cable to the can of the motor, making a strain relief loop.
Usually, I would try such a repair and still just replace, but am feeeling quite confident in this one.
1ricardo - will send you a PM.
My Feedback: (24)
Yup. Ya' know, you never really leave, I think.
Actually bought JR's old Discovery jet from him last summer and am re-habing it. Not it bad shape at all and very tidy installation.
Just easing back into the hobby as my kids still have priority; one going into high school and one not far away from it, so still not a lot of time. Hoping to fly at the Houston fly-in in 2 weeks.
Going to see you there David?
