Fiberglass vs Kevlar tank?
Hi all,
I'm in the process of kicking off a new project - a Pirotti Tuono Easy that will be VT80 powered. The optional molded tank I bought from the manufacturer is a fiberglass unit and fits in the model perfectly. My other turbine has a Kevlar tank setup. My gut feel is that the kevlar option is probably tougher, but are there any folks here with first hand experience on if it is worth investing in having a custom Kevlar one made? the advantage of the fiberglass one is that it fits perfectly and I already have it!
Opinions and facts welcome...
Having never crashed my jets I have no empirical data to argue the previous post however, Kevlar is a lot stronger (and less brittle) than fg. Why else would people use Kevlar tanks? If there is less chance of a Kevlar tank rupturing and everything burning, then I cannot see the down side to using kevlar (except cost).
AB, CANADA
I would suggest that a product with a high tensile strength (Kevlar) generally does not have a high elasticity or ductility. That being said, Kevlar looks shiny but you'd be better off with a 2L pop bottle.
Dale
Dale
My Feedback: (176)
I dropped my super Scorpio fuel tank from 6" on the garage concrete flor and the tank split open ,good the crack was the glue sim so was easy fix ,and just last year in Kentucky jets I witness two fuel tanks crack open doing refueling ! The biggest reason wy the jet companies using the Kevlar fuel tanks -the easy to make and no need to do expensive injection mold.
I'll add my .02:
FG will get pinhole leaks very easy if you fuel too fast. A with Kevlar, fueling too fast can rupture them. There is little warning as well. You would be suprised at what is "too fast" as well.
Plastic on the other hand usually will not rupture, but they can balloon up and create a lot of pressure that takes minutes to stabalize. There is a guy in the JL viper thread who forgot to remove his vent plug, her flew and when he landed the plastic tank had callapsed down very far. If it were FB or kevlar would of been a disaster.
A negative point of plastic is static, the fuel will swash around the plastic making much more static.
I have all 3 tanks. Plastic is the safest but ugly.
My Feedback: (24)
As long as the fiberglass tank is well made, such that it doesn't crack when fueling, I'd use it. BTW, I've had several Kevlar fuel tanks (including BVM and JetTech) develop cracks from fueling too, so they are not significantly better in that regard.
The poster above is correct in that the manufacturers of jet models use Kevlar or fiberglass molded tanks because the mold for that is *much* cheaper than one for a plastic tank.
That being said, as far as crashes are concerned, I've seen (actually had myself) plastic DuBro tanks split open on a crash - both in jets and in giant scale prop planes. If the crash is bad enough, any tank is going to split open and spill its contents. The plastic ones may be slightly more robust than composite and Kevlar might be *slight* more robust than fiberglass, but in reality, its not enough of a difference to be concerned about.
Kevlar just looks cooler...
Bob
Bob
My Feedback: (44)
I have personally tested the plastic du-bro / Sullivan type tank in a "real jet crash situation" ... I'll take the plastic tank any day over fiberglass or Kevlar.
I have also seen Kevlar tank is a crash, the issue is the Kevlar tank won't necessary split, it can fracture allowing a "MIST" of fuel which is far more likely to ignite than a large splash of fuel.
Where as the plastic tank is more likely to split, with a large volume of fuel in a liquid state dispersing all at once. It is much harder to light a pure liquid fuel oil / Jet A than a mist, the mist will explode under the correct air/fuel mix ratio. (Think about the high pressure fuel injectors used in a diesel engine, the fuel is misted into the combustion chamber)
My Feedback: (176)
There is little solution for smaller Kevlar and fiberglass tanks to put them in think wall IV bag and secure tide in front this will prevent from fuel spray and big spill the IV bag it's super strong and almost impossible to ripped when heated will tide around the fuel tank and give extra strength .jet central no issue so funny specially the compressor in super eagle.
1 Post
Interesting to hear these comments and I wanted to highlight some issues which have been raised here.
I manufacture the CAT, a UAT product, since I designed the first prototype I was aware that many issues around leaks, tank ruptures/cracking etc occurred during fuel filling, the reason being the fuelling station pumps deliver way too much pressure, way more than most fuel system vent systems allow for. I reduced the barb size on the CAT at the fuelling stage so that the fill pressure was reduced before the fuel tanks etc were over pressurised - hopefully reducing the possibilities of a damaged main tank etc.
We need to be very careful filling jet fuel tanks regardless of the material used - this I feel is more important than wether they are FG, KV or PET.
marcs
marcs
Kevlar sounds sexy, fiberglass has it's issues. Polyethylene and PET sound cheap but they actually perform better.
Whatever is easiest and fits best is the one to go with. It's not about the tank material in a crash .. it's about the crash.
Dead stick crashes rarely burn but I've seen the fuel tanks rupture. It's about the energy absorbed on impact.
Crashes under power are the most likely to fireball and at those speeds no tank will survive. Heck, here we are discussing rupturing a tank from filling it too fast, a crash is certainly a more destructive event.
But it is interesting to see pilots think that a Kevlar tank will save them on impact. Just a myth IMHO.
Here is my plastic fuel tanks and one small test about rupture.
https://www.youtube.com/watch?v=zWm-h2GtNis
Hello friends:
i make and sell fiber glass tanks, really are more cheap that Kevlar and in the end the result are same.
i can make the shape that you want for few $$$$.
you can see a sample here, the Skymaster T-38 Talon tanks, 5L of kerosene.
regards from Spain
Carlos
_____________________
www.cmjets.blogspot.com
regards from Spain
Carlos
My Feedback: (39)
marcs
marcs
so I agree, we need to be carefull but also do not underestimate the need to keep the restrictions throughout the system to a minimum. This will help both the fuelling of the tanks and operation of the turbine fuel pump as well.
Also agree that the Dubro poly tanks are the best and the only ones that I have seen survive in a crash.
PaulD
I would prefer to fit Dubro poly type tanks whenever possible. As I have witnessed they will survive crashes much better than fibreglass or Kevlar. Kevlar sounds a lot more exciting hi-tech(expensive) and I guess that has been the attraction.
John
John
Really, the matter if use fiber glass of Kevlar tank not is if the plane crash, is for make an special shape tank suitable for each model, if them the tank break in an accident, this is another question, I think.
Carlos.
Carlos.
My Feedback: (86)
Most of the strain comes from fueling and de-fueling, depending on the battery voltage you are using...it can expand on fueling and compress on de-fueling, cracking joint lines and even causing the skin to finally start cracking all the way through. As stated above though, a good fuel plumbing system is CRITICAL. Large ID tubing and enough venting really helps the "taxing" of the tanks, Kevlar or FG as it is fueling and de-fueling.
I agree...Kevlar looks cool! But I have had both FG and Kevlar and ONLY with Kevlar tanks have I had any issues with leaking. I go with whatever the company I am buying from gives me.
Rex
Rex
Thanks guys, Going by the comments there does not seem to be a compelling reason to change so I think I will stick with the FG tank. Appreciate the help,
Geoff
btw, I use a manual fuel pump.
Geoff
