Hitec 7954 Servo Failures
#51
Hello,
We are using Hitech servos from many years ago . No problem so far.
My F-18 which weights more than 70Ib is all powered with 7954s . Two servos each flap which shows the huge size of it. And no problem at all.
You have to be very careful when you buld the servo .if they are forcing will burn whatever servo brand is. We usually use an ammeter to confim that nither servo on the airplane is overworking, expecially the flaps one.
Some years ago I trusted in Hitech brand for my Ultra Bandit from BVM. Lot of people told me I was crasy thinking in put Hitech servos on such a fast airplane . After 5 years muy ultra Bandit still flying with the same Hitech servos that I used for my maiden flight.
I have never had any problem with them and I will continue using them for sure.
Raúl
Raúl
#52
Update....
We received 6 Hitec 7954 servos back from Hitec this week. 3 were replaced and 3 have been repaired, all at no charge and free return shipping. I am out of town and have not decided how I will use these servos yet. But it seems appropriate to acknowledge Hitec here now for their positive response to my issue.
Once I get them back in the air I will post another update.
steve
steve
#53
Update....
steve
steve
Jim O
#54
Jim,
No info from Hitec, just the repaired/replaced servos returned. I have re-installed all wiring and servos in the jet. I have ordered a Hitec servo programmer and plan to set overload protection at 20% per Mike at Hitec. I also plan to program in the failsafe feature. Hope to fly it at the basin this Friday and will report back.
Steve
Steve
#58
I am considering using the Hitec HS-7245MH as a direct drive steering servo in a big Corsair to give a bit of of added torque. Right now I am using a HS-225BB and In some conditions when the plane is stopped the servo may stall. While it is rolling it steers fine with no problem. How do you recommend setting the overload protection using the programmer to have maximum torque but at the same time protect the servo from burning out if it stalls
I have the HFP-20 programmer.
#59
It seems to be only Hitec high voltage servos that have a problem. I have been using Hitec digital servos for years with no problems & I will continue to use them.
I did buy four Hitec HS5685HV servos & all four burned out within a month.
#60
Hi Jim;
I have not had a problem with standard size servos burning out. However, in a jet i used one of the Mini Digital Servos model HS-5245MG for the mechanical sequencer. I accidentally let it hit the stops and it was gone. Later on I did the same thing with another one. I've been using the really cheep analog version HS-225BB since for this with no problem. When the HS-225BB is used in my the tail wheel retract, the plastic gears are starting to go. I want to go back to something more powerful with metal gears but I know that it may stall and my experience is that it will quickly burn out after that.
I saw that the HS-7245MH has over load protection that can be programmed in. The torque is reduced to save the servo if it is stalled. My question is how can I tell what the maximum stall torque is with out burning out the servo? Maybe I need to monitor the current but what is the maximum amount?
#61
My Feedback: (61)
We have had a series of flap servo failures on several turbine powered jets at our airfield of late. The latest victim was an Avanti that experienced 2 fried Hitec 7954 flap servos in flight causing catastophic failure. I experienced a similar failure in my Ultima-tun 2 meter turbine powered jet. While I did not lose my plane I do not want to fly again until I understand why these high voltage digital servos are failing. None have been observed to be binding or otherwise hitting the end of their control throws. No shorts in any wiring have been discovered either.
Tomorrow I am sending several of these off to Hitec to take a look at. In the meantime I wonder if anyone has had a similar experience?
Steve
Steve
