Skymaster Leaking Gear Struts >
Old 06-07-2014 | 08:30 PM
Default Skymaster Leaking Gear Struts
I have some struts that leak air. I followed the direction for adding oil etc.
Has anyone tried using BVM thin lube in the struts to stop air leaks?
Old 06-08-2014 | 05:31 AM
Gonzalo38's Avatar
I have a couple of older Skymaster jets that had the same problem. Over time, fluid will start leaking and no air will remain inside.
I solved the problem by using high viscosity silicone like the one used for RC Cars. http://www.ofna.com/fluids.php
The one that originally comes from the factory is way to thin and and with a higher viscosity you won't have a problem again. Currently I'm using a 7.000 weight.
You can also try to use something like the Dow Corning 55 Valve Lube to lubricate the o'rings and keep them in good shape.
Old 06-08-2014 | 01:02 PM
Springbok Flyer's Avatar
Yes, like Gonzalo, I also changed the oil. I am now using a power boat power steering oil with good results.
Cheers,
Jan
Old 06-08-2014 | 07:12 PM
I may get a new set of seals from skymaster, and I am also going to try thicker oil.
Thanks for the advice, I think my local HS has the car oil but if not I will look into the power steering fluid.
Old 06-09-2014 | 11:47 AM
Emailed Skymaster and they are sending a new set of seals. Not sure if they will charge or not, just asked for my address.
I picked some heavier RC car diff oil as well, 7000w.
I wasted a lot of time taking these apart, reoilin getc time to get this fixed. Thanks Skymaster!
Old 06-09-2014 | 12:04 PM
ravill's Avatar
The first time my Skymaster struts leak, they get springs. Forget the oil.
