Reload this Page >
Fei Bao Jets Dolphin build thread by RCISFUN
Old 07-29-2015, 06:56 AM
  #201
Albie1077
Just out of Paint my New Dolphin
ID:	2111635   Click image for larger version
Old 07-29-2015, 07:23 AM
  #202
tp777fo
My Feedback: (28)
tp777fo's Avatar
Very nice!
Old 07-29-2015, 10:26 AM
  #203
Gary Szetlak
My Feedback: (13)
Originally Posted by causeitflies
Rich,
I only have three landings on it so it could be me. Also I was cutting the throttle up high and making a steep descending turn to final. It didn't seem like it picked up a lot of speed but apparently it did. I have a little down trim dialed in for full flap that I'll also take out. I ran the engine yesterday just to confirm the idle on the 210 and it was normal.
I used the CG machine yesterday to compare the hung CG. There was 1 mm difference and the plane weighs 37.48lbs.
Yes, I'll be at Titusville. I'll see if Gary or Rich want to go too.
Tom,
My struts were sticking because the screws at the knee were too tight. They are smooth now.
I plan to be there Saturday morning. Be carful with those screws in the knee action part of the strut, mine were loose and actually fell out during transprort. I loctighted them just short of bottoming out so that the knee works but the screws can't back out and fall off
Old 07-29-2015, 12:05 PM
  #204
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
I hate it when my screws fall out see you Saturday
Old 07-29-2015, 01:39 PM
  #205
tp777fo
My Feedback: (28)
tp777fo's Avatar
Many people throughout the years have said that I have a loose screw.
Old 07-29-2015, 02:04 PM
  #206
causeitflies
causeitflies's Avatar
Gary, I lost two of them. That's why I made them too tight when I replaced them. I locktite'd them same as you now.
Old 07-30-2015, 08:11 AM
  #207
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Albert, that looks great!
Old 07-30-2015, 08:13 AM
  #208
Albie1077
Thanks i have a concern they did not close out the wheel well and I dont see trailing link gear
Old 07-30-2015, 08:23 AM
  #209
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Wow, I see that now, I'm sure Eric will get on it for you!
Old 07-30-2015, 08:29 AM
  #210
Albie1077
ohh well Eric is on the case all good....
Old 07-30-2015, 08:35 AM
  #211
causeitflies
It looks like the Ferrari scheme is the only one with the up-swept wing tips.
Old 07-30-2015, 08:44 AM
  #212
Albie1077
I think so and my friend is flying that one down here
Old 07-30-2015, 10:16 AM
  #213
tp777fo
My Feedback: (28)
tp777fo's Avatar
I just sent a message to Eric asking if he could get a supply of knee pins, screws, washers, e clips etc so we could have some spares. I just checked my knee pins an screws and found one just about out. I had locktited both earlier....guess I need to use more
Old 07-31-2015, 07:42 AM
  #214
Albie1077
Gear Problem resolved... Will be corrected
Thanks Eric
Old 08-03-2015, 05:49 PM
  #215
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Hey Albert...parts on the way
Old 08-03-2015, 05:56 PM
  #216
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
We had a Dolphin get together last Saturday at the Titusville Airport with Gary and myself, Mark missed out because he couldn't make it.
Gary made an interesting stand to assemble his Dolphin.
ID:	2112821   Click image for larger version
ID:	2112822   Click image for larger version
ID:	2112823   Click image for larger version
ID:	2112824   Click image for larger version
ID:	2112825   Click image for larger version
Old 08-03-2015, 06:02 PM
  #217
Albie1077
Thanks Rich I will let Jimmy know its on the way I have a funny feeling the gear error is a major booboo so my dolphin might be delayed some what.
Albert
Old 08-03-2015, 06:06 PM
  #218
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
At least it was addressed before shipping!
Old 08-03-2015, 06:13 PM
  #219
Albie1077
Yes sir im glad we where talking about the flap modification and then I noticed it on the photo
Old 08-03-2015, 06:34 PM
  #220
causeitflies
Couldn't make it to Titusville but I did manage to get three more flights and six landings on the Dolphin late Saturday afternoon at the Nighthawks.
I tried landing with no down trim but in the end I set the trim right back where it started (down trim). The plane just seems happier at this setting. Of course there was a nice headwind so I'll still be experimenting with the settings.
Old 08-04-2015, 03:13 AM
  #221
tp777fo
My Feedback: (28)
tp777fo's Avatar
Sweet jets guys! Hope to get some more flights on mine this weekend. It's a tough flight at our field. Several no overfly areas so I have to keep it moving, at the 170ish its flying I have at most 2-3 seconds before a turn. But.....I have lots of vertical to pay with . I dont take mine apart as I have a large trailer but it is still a bear to handle due to it's size.
Old 08-04-2015, 03:03 PM
  #222
causeitflies
Mine just barely fits in the van in one piece...
ID:	2112885   Click image for larger version
ID:	2112886   Click image for larger version
Old 08-04-2015, 05:28 PM
  #223
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Mark I have to remove my center console in my Town & Country in order for the big Dolphin to fit when its all together, the Small Dolphin just fits without removing the console.
Old 08-04-2015, 05:40 PM
  #224
causeitflies
I don't have a center console but it doesn't matter as the plane sits on a shelf and would be above it. Wings, chair, pop-up, wagon, etc. go underneath.
Old 08-10-2015, 12:26 PM
  #225
tp777fo
My Feedback: (28)
tp777fo's Avatar
Ok guys, here is something to be aware of. My pvc cradle's front crossbar (foam covered) is just in front of nose gear. As you can see it cracked the airex on both sides. I repaired it with 1.5" cf strips with CA to make a rock hard opening for the gear. I also trashed the cradle and made an 8" deep foam bed with the cutout of the fuselage. The bottom 4" is solid foam and the cutout is the top 4" Foam will be placed over the hold down straps. I havent put a scratch on the plane flying it but I am beating it to death doing stupid stuff like the pvc cradle I made at first.
ID:	2113769   Click image for larger version
ID:	2113770   Click image for larger version
ID:	2113771   Click image for larger version
