Reload this Page >
My SM F-14 Tomcat
My SM F-14 Tomcat
Old 09-21-2014, 10:11 PM
  #176
WimB
WimB's Avatar
Originally Posted by Alex48
Hows the nose section secured Wim? is it bolted onto the front former?
Cheers, Alex
Alex, yes, it will be bolted to that former. I will need to reinforce the mounting points. The tray will be supported at the back as well.
Wim
Old 09-21-2014, 10:14 PM
  #177
Alex48
Alex48's Avatar
Good idea, that plywood is like cheese.
Old 09-21-2014, 10:18 PM
  #178
WimB
WimB's Avatar
It is indeed....... on the tray, the wood is reinforced by a 1mm carbon sheet. I'll probably back the former with proper plywood, and install triangles to tie it into the fuse. Wouldn't want to see the nose come off after a landing, lol!
Old 09-22-2014, 12:35 AM
  #179
muzzgail
muzzgail's Avatar
Hollywood Wim. Loving your build.
Old 10-11-2014, 08:14 AM
  #180
WimB
WimB's Avatar
hey guys, done a lot of work in the meantime, check out my new vids........
http://youtu.be/FRbjKz2HcGM http://youtu.be/FRbjKz2HcGM http://youtu.be/fOGdUfCUixA Enjoy!!
Old 10-11-2014, 11:01 AM
  #181
muzzgail
muzzgail's Avatar
Well done Wim. Sounds like she is coming together nicely buddy.
Old 10-11-2014, 01:31 PM
  #182
FenderBean
FenderBean's Avatar
Man seeing the gear work worries me with hang ups on the up, Wim how do u have your gear and doors setup, 1 valve for all 3 gear and 2 for the doors? Looking good mine is ready for paint!!!!
Old 10-11-2014, 07:19 PM
  #183
Chris Nicastro
Chris Nicastro's Avatar
Increase the air volume so it has more authority. If theres room for another tank or two its worth it.
Old 10-11-2014, 10:14 PM
  #184
invertmast
My Feedback: (23)
invertmast's Avatar
Looks good Wim. What you gear and doors are doing is exactly why im going hydraulic and custom cylinders on my tomcat.
Old 10-12-2014, 12:00 AM
  #185
WimB
WimB's Avatar
@ Fender: I ordered mine with the 5-in-1 valve. although it doesn't have the right program for the tomcat, it can work if used in conjunction with an extra valve on the powerbox sequencer. this is how i did it on mine.
@ Chris: indeed, I installed two large Robart tanks above the inlets, and joined those for the gear and doors. I then have two of the original tanks under the pumps and UAT's, one for airbrake + brakes, other for canopy and tailhook.
@ thomas: the left main gear did hang up a bit, much better after some careful application of WD40, lol.........
@ Muzz, thx mate!
Old 10-12-2014, 09:34 AM
  #186
Chris Nicastro
Is it better now or does the video show the extra air volume performance?
Old 10-12-2014, 10:22 AM
  #187
WimB
WimB's Avatar
Chris,
this is with the extra tank, but after lubrication, they go up a lot smoother.
W.
Old 10-14-2014, 04:20 AM
  #188
mick15
mick15's Avatar
LG action http://youtu.be/_XYx4dqBuFE
Old 10-14-2014, 06:55 AM
  #189
FenderBean
FenderBean's Avatar
man I was really hoping someone converted theirs to hydraulic, I was really hoping to do that to mine!!!
Mick would you send me or post how you did yours? Im here in the states and cannot find anything local so I guesss im going to need to order from overseas. Looks good seems to work really smooth, did you convert everything to hydraulic or just the gear? Thanks
Old 10-14-2014, 07:20 AM
  #190
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
you are getting into a world of hurt with hydraulics... better get some 300 psi nylon line as polyureathane can't handle the loads hydraulics need.
Old 10-14-2014, 10:24 AM
  #191
invertmast
My Feedback: (23)
invertmast's Avatar
Judging by the slapping of the doors, im betting they are still pneumatic
Old 10-14-2014, 10:59 AM
  #192
schroedm
schroedm's Avatar
Gear is definitely hydraulic. You can hear the pump. Doors might be air still. Sure Mick will clarify
Old 10-15-2014, 02:05 AM
  #193
mick15
mick15's Avatar
Yes Mark is correct, the gear is oil and the doors are air. It would be too complicated to have the doors hyd as they have to be timed requiring two more distribution valves and two more servos.
I may be tempted in the future to have the secondary doors oil operated ie the nose doors, the small and outer main doors because I'm not happy with the transition speed.
The system is basically the UMS (India) kit with the ECU replaced by my own accumulator which controls the pump cycle, there is a picture of this in a previous post.
I have modified 10 or a dozen models now and have not yet come across cylinders that cannot be modified to 4mm operation. The last one I did was my Airworld Hunter.
m
Old 10-15-2014, 03:19 AM
  #194
WimB
WimB's Avatar
Default Balancing act.....
Well guys, hardware on mine is about done, still need to adress some minor things, but in all, it's finished!
still have a lot of programming to do though, and doublechecking of course.
I sent in my actuators today for an upgrade, will be changed to full alu version.
I did take the time to check my balance, and it does come out quite well!!!
here she is "hanging in the ropes' so to say....
I'm very happy with the outcome: to balance her per the manual, she only needs 285g of lead in the nose, to balance her just in front of the wing mech, the lead needs to go in the back. so without any lead, she'll balance about 1cm in front of the pivot mechanism. I weighed her as well..... 28kg, dry, with filled UAT's.... oh, if you fit long bolts to balance yours, be sure to fit véry strong M4 bolts.... mine bent, lol!
W.
Name:	DSC_0154 (Large).JPG
ID:	2040408   Click image for larger version
Name:	DSC_0157 (Large).JPG
ID:	2040409   Click image for larger version
Name:	DSC_0155 (Large).JPG
ID:	2040410   Click image for larger version
Name:	DSC_0153 (Large).JPG
ID:	2040411   Click image for larger version
Name:	DSC_0156 (Large).JPG
Old 10-15-2014, 04:02 AM
  #195
mick15
mick15's Avatar
Where exactly is the model hanging from, can't quite see?
m
Old 10-15-2014, 04:08 AM
  #196
WimB
WimB's Avatar
Mick, it's suspended from the ceiling, with the orange straps, who are connected with hooks to a strong string (yellow) going to the long bolt.
next pic probably shows it better...
Old 10-15-2014, 04:20 AM
  #197
mick15
mick15's Avatar
No I mean at what point on the model? It should hang from a point touching the front carbon cross member.
m
Old 10-15-2014, 04:28 AM
  #198
WimB
WimB's Avatar
Mick,
per the manual, initially it should be balanced about 2cm in front of the CF cross member.
at this location, it needs 285g nose weight. suspended just n front of the CF spar, it needs the same weight in the tail. so without weight, it balances between these two extremes.
Wim
Old 10-15-2014, 04:32 AM
  #199
mick15
mick15's Avatar
Having just completed the hours flying for the CAA I can tell you mine would be nose heavy at that setting.
m
Old 10-15-2014, 04:35 AM
  #200
WimB
WimB's Avatar
okay, then I guess I won't bother with adding lead to it, and that would mean I have achieved my goal, NO LEAD!
W.
