Big FEJ Hawk Down - wing collapse Reported
NV
Based on what we all know about FEJ's inherent design flaws and poor quality, flying a FEJ jet at rallies is irresponsible. For crying out loud this is two for two with the same pilot! It's not like this is some sort of isolated event with FEJ. When is this community going to wake up and take a stand against this company from participating in rallies?
Ghostrider 1
NV
The AMA is to busy spending $250K trying to find a way to make $$ with their own quad copter business and training for commercial use.
#31
My Feedback: (17)
Actually, the AMA has no current rules regarding an AMA member flying an ARF that has a widely known design and manufacturing defect. Any AMA member that want’s to can fly one, crash and injure/kill someone and the AMA insurance provides full coverage. And the club or CD that allowed the flight is also protected by the AMA insurance if sued. Sounds pretty dumb but that is how it works. Feel free to ask too, but that is the answer I got.
#32
My Feedback: (154)
CA
This community will not wake up until someone is hurt or someone losses a large chunk of cash (RV) due to these POS's going in. Then it may be too late!
The leaders of this community are the CD's and club officials. Until we man up and say No, this will continue.
#33
You guys whinging about FEJ in the last month I've seen to skymaster jets a F-16 and a large viper both have the fins blow a part in flight one of them landed safe and the other crash both of them are top pilots. All of the manufacturers have problems.
Damo
Damo
#34
The quote comes from a deleted post so has to go
Let's start at the source ... OK?
Does anyone at FEJ have an engineering degree? The answer is, "No."
The REAL engineers (stress & structure, mechanical, aeronautical (including guys from Boeing and NASA)) have already commented about FEJ's lack of knowledge and poor designs here on RCU in such deep and thorough technical terms that it would blow you away. Just research the topics, and see for yourself.
I have edited out names and quotes but left the rest of the post rather than just deleting the whole post as what is being said has value.
#35
Hi,
Let's face it-- the real power/impetus/responsibility lies with the CD of the event. He would be inviting quite a ***** storm if he were to announce that a specific brand of ARF's weren't welcome at his event, so he so far won't do it. Until one of the CD's takes this step, it's all just a bunch of whoof-whoof. I think that when someone does finally take that stand, the rest will follow suit.
#36
I have owned 2 Skygate Hawks, and have flown 3 others. I have 3 friends that own them who fly quite often, and then I would guess at having seen maybe another 5-10 fly a ross the world on my travels. The only time I have ever seen an issue with the rudder was on the prototype model when it was first released at the jet masters. That issue was a result of the rudder servo failing and causing flutter in the entire fin. I know as I watched Stephen Volker replace the servo on more than one occasion, go out and do another flight. Only for the same result. Half way through the flight as the rudder was loaded the servo or something in the servo set up would fail and always with the same result. Sorry but I do not thnk it is a model issue.
Mick, dont get me started o how many Airworld hawks I have owned, flown or seen fly with no issue what so ever.
I see it more and more often where the larger planes are flown in the same way as the smaller jets ( hard ) most of the time the pilot gets away with it, but sometimes not. At the last jet meeting I was at I watched a very competent pilot, who normally flies mainly smallish sport jets ( Bandits, etc ) Fly his new MB339. He was flying it really well, but just a little to " Hard" in my opinion. I went over and had a word with him, just offering some advice and trying to explain how these large heavy scale models have so much inertia behind them that it's easy to let the speed build up, and then when flown in the same manner as a sport jet that can be pulled and pushed much harder the loads are so great it can cause a failure. He took the advice on board and will hopefully get any enjoyable flights on that model.
I am just getting into full size flying and as part of it I am trying to fly as many different types as I can. The thing that amazes me is the different VNE's ( Velocity never to be exceeded) There are. Its amazing that two very similar looking aircraft can have such differing VNE's! I think its the same with models. For example.. I have seen people fly jets like Bandits, and Bobcats so , so hard with no issues. Yet I have seen models such as big L-39's and large deltas fold up like a paper bag mid flight in what looked to be a pretty tame flight. It's so difficult to give a comprehensive answer without going too technical. it's also so difficult giving a defined limit for each model. As most manufacturers do not test to destruction, and no models that I know of have a VNE. Even if they did how would we measure and monitor that we did not exceed them?
For me the way I try to work round it is I try to adopt a different style of flying for each model.
I have flown and will quite confidently fly a model such as my BVM Bobcat much harder, faster and more aggressively than I would something like my Skygate Hawk. I try and avoid mixing speed with high G maneuvers. Yes I do some pretty damn fast high speed runs, but I work up to these ( during flight testing away from a show environment before I get flamed ) I also do some high energy sharp pulls, but these I do turbine spooled down. I know for sure that if I mixed both those two aspects f my flight that it would be Bye Bye Bobcat!
The same as when I fly my Skygate hawk ( P-180 powered by the way ) As soon as I am off and cleaned up I am back on the throttle, and I am using that throttle stick nearly as much as some of my flight controls. I watched a Skygate fly in Italy once and the only thing that saved it was the fact it flamed out. The pilot took off and from the moment he took off till the moment it flamed out the pilot never once touched the throttle stick ( No I could not see it but I sure could hear it) The model got faster and faster till it reached it's maximum speed. I was fearing the worst as the pilot was just getting settled in and I thought if he goes for any vertical maneuvers this could be curtains. Luckily the turbine shut down just as he was pulling 45 for what looked as it it might have been a half reverse cuban ( Which I think might have been the first and last time for that model ) After a perfect landing I went up to the pilot and tried to explain that he might try and adopt some throttle management, to which he informed me that he was famed in his local club for flying pulse jets ( No throttle ) and he had never had one of those fail. I did try to explain to him that a small pulse jet delta, although flying fast does not have the same flight loads on the surfaces or controls as this big hawk... Not sure what the outcome was but I am hoping that all went well.
Sorry to waffle on guys, and please dont treat this as me pointing fingers, and having a preach. I am simply just trying to convey some of my experiences ( Good and bad ) As well as some of my worries.
If I can ever be of any help, or give ay advice then please feel free to get in touch.
Regards Al
Regards Al
#37
Ali,
I appreciate your response and what you say is very true about throttle management - for everyone and every manufacturer out there. The problem I have understanding your response as it relates to FEJ is that for the most part a curtain percentage of jet flyers of all makes, not just FEJ have and always will (as discussed not necessarily the best thing but do anyway) over throttled their jets. This happens across the spectrum of manufacturers available. The problem is that FEJ, given that this speed problem is universal to all pilots and all manufacturers, is having a disproportionate amount of airframe failures compared to the rest of the pack.
The other problem with this argument is that Lewis is not known to over speed his jets. At least I have not seen him over speed one of his jets. Now I was not in attendance during the previous two failures he experienced but the times I have seen Lewis fly the flights are very conservative.
#40
My Feedback: (38)
not on this subject, you get the same regulars,shooting out the same info and opinions,
Its great, I did read and learn,, I do own one of the older FEJ f-16s no honeycomb junk in it, good solid ply, the plane is strong, and it flies and looks great, but the price to pay for the build quality comes in at the scales, my plane is fairly heavy when compared to the new honeycomb designs. I did a lot of reading before purchasing mine from another member, Making sure it was not honeycomb build. I got it and Iove the Jet, but I was warned about the Gear from multiple people, and it was true, I have had my issues with the gear, I spend another 700 and had them converted at down and locked and that took care of the gear problem (I did have two of their actuators fail, but they stepped up took all three and updated them to the new strong transmission system). So when I look at my jet, it looks great, everyone likes it, takes off straight flies straight, and lands OK, I still need some fine tuning, but all in all it has been a proven jet, the previous owner had multiple flights on it, I have now had 9 flights on it. I can trust my jet, to stay together, if I can keep the landings well. I am also in this jet for almost 6k I bought all high end components, Tams Pipe, Good Batts, Jetcat p120sx, the only real problem with mine is its heavier than any other 1/8 f-16 out there. SO WHEN I READ THESE COMMENTS SAYING AMA/CD's should ban all FEJ planes, I say that's BS, not all, there are still plenty of older fej airplanes still flying, NOW PERSONALLY, from what I have read on this forum,, Would I buy a new FEJ,,,, Honesty,, NO, I have no confidence in their current building techniques with this honeycomb being used as support,Im no engineer, but I do know you want something solid there to hold. I am also not happy with the customer support, they have burned many,,, BUT also I can see it like this, did they build the plane, yes, are they responsible for the plane, (lawyers would love to get some of this question) Is the customer the one in the end holding all the responsibility, YES, you take that risk anytime you purchase something in this hobby. You try to learn from others experience, and advice, and use that to make a sane judgment. SO when it comes to this subject, instead of getting angry at people who bought what they thought was a good jet, OR EVEN some who were told they would build it their way,, that anger should be turned to the manufacturer, and eventually you will get 1 of two results, they will step up and try to take care of what the problems are and peoples losses, (I don't see them doing that, I see that putting them in bankruptcy) Or they ignore all the bad pressure, and continue on going the way they have been just ignoring it all, and I see that putting them in Bankruptcy too. What I would do is completely shut down, sell off all the parts, then work with the manufacturer, have the flaws on airframes fixed, then start up a new company with a new beginning, and try to keep its customers secure with their product. I know this strategy works I have seen it done multiple times at Chinese buffets in town.......this is just my two cents on the matter,
#41
Raron,
Don't think you are immune from total FEJ catastrophe just because you don't have honeycomb. My 1/8" FEJ F16 was an earlier non honeycomb design too. It blew up in the air at around the 80-100 flight if I recall.
#43
Mick, dont get me started on how many Airworld hawks I have owned, flown or seen fly with no issue what so ever.
That needs to be qualified. Mick B lost his Airworld Hawk after the fin detached.
The fin spar on the original AirWorld Hawk was poor quality ply, neither long enough or strong enough for the task. Add some fatigue, perhaps rough air and off comes the fin and complete loss of control as happened at a public display.
I originally built my two Hawks with the original fin spar, as I assumed it had been thoroughly flight tested.
After the fin spar broke on one model, fortunately without loss of the model both of my Hawk fins were substantially strengthened and stiffened, its not difficult after removing the jet pipe and working through the airbrake recess. Geoff White flew his AW Hawk with a Pegasus but had incorporated the fin mod. at original build. Many flights with zero problem.
I reported this problem to H-D but don't know if he took any action.
That said, if you are flying an unmodified AW Hawk, you have, potentially, a lethal problem waiting for you.
I still have two AW Hawks (also with much improved landing gear mounts) and now have complete confidence in the structural integrity of the airframe, proven over many flights and now with JetCat 180 RX power, the perfect engine for this model.
The SkyGate Hawk can also be improved in this area too. After seeing the fin flutter on the original SG Hawk in Hungary, I substantially strengthened the supporting structure for the fin post on mine, it looked rather inadequate to me, no doubt caused by the urge to keep the weight down to 20kg.
David Gladwin.
David Gladwin.
#44
1 Post
I'm not sure why this has turned into a SG and AW Hawk discussion. Also, it seems adocape1414 is not Ali. That post, from memory, is a copy and paste of Al's views from months/years ago in the SG/TH Hawk thread. Odd.....
#45
Quite simple, this thread is about structural failure, FEJ particularly.
"Someone" mentioned two models of a type I have built and own, I know them intimately. I added my own comments about what I believe, know, to be structural problems and modifications I have incorporated to improve them, "spreading the word" in the absence of any formal system as we have in fullsize aviation. The risk of structural failure is unacceptable when it is a known problem.
My guess is we will see more and more structural failures as some fliers insist in installing bigger and bigger engines in airframes of inconsistent quality and flying them inappropriately.
David G.
David G.
#46
Pattern not found.
P.S Sry not defending FEJ.
#47
My Feedback: (57)
For the record, this forum is so biased.
I see people here not treating Lewis the same way they treated others when the same thing happend. Easy to chew on strangers right? Hard to chew on the CD of the grandest jet event in the US, right?
No need to answer......this is only food for thought. I feel just as sorry for him as I do for all the other victims.
#48
My Feedback: (24)
Wasn't the crash at Top Gun 1997-1998 (I think) caused by a scale folding wing mechanism that activated while he was flying (not his fault right?) I know one of his A-7 had a midair with another jet but that doesn't count either right?
Pattern not found.
Pattern not found.
Bob
#49
My Feedback: (24)
Bob
