Jet Munt VT80 question
Hello!
The cable that goes from the turbine would i like to extend.
Should I use this http://www.xicoy.com/catalog/product...roducts_id=247
or this http://www.wrenturbines.co.uk/spares...extension-lead
The cable that exiting from the turbine has 4 corde, the cable Xicoy sells only has 3 lead.
What is right?
Excuse for my bad English
Regards
Sejenssen
Norway
What is right?
Regards
Sejenssen
Norway
IMO there is no reason to extend the entire cable, Either you would want to extend the two wires going to the pump or extend the battery leads coming from the battery itself.
I would not use the Wren lead without first checking to ensure that the cable/plug configuration is consistent with the Munts cables and plugs.
I had to mount my VT 80 pump and battery further from the turbine that the stock cable would allow. I simply soldered in two additional lengths of cable on the pump lines, and used a two cable extension for the battery. As Ira d suggested..
Brilliant little engine by the way..
