Led afterburner ring module identification / programming >
Old 11-29-2014 | 06:02 PM
bri6672's Avatar
Default Led afterburner ring module identification / programming
He guys I have an LED afterbuner ring setup that came with a used model. I'm trying to figure out the programming as the previous owner had no idea of the brand. Anyone recognize this or can provide any programming instructions???
Old 11-29-2014 | 10:15 PM
number27's Avatar
looks similar to an xicoy unit. i think the red heatshrink is an after market mod.
Old 11-30-2014 | 01:35 AM
bri6672's Avatar
It thought that as well but the instructions and pictures from dreamworks look and function differently....
Old 11-30-2014 | 04:31 AM
lookilook's Avatar
Hi , I am not sure but looks like mine which i also got some years ago from Dreamworks and i believe was manufactured by airpower.
I had a problem so i was given a name ''Rainer'' to contact...unfortunately i cannot find the emails exchanged to confirm is airpower.
if you see my videos which i have sent to Rainer back then to explain to him what was my problem you should be able to figure out the instructions.
Hope this help...
https://www.youtube.com/watch?v=0efM...faKg&index=110
https://www.youtube.com/watch?v=M6bs...faKg&index=108
Nicos
Old 11-30-2014 | 08:37 AM
bri6672's Avatar
Nicos, thank you so much that's the stuff I needed!! How's your F-18 coming along?
Brian
Old 11-30-2014 | 09:24 AM
lookilook's Avatar
Good to hear that Brian .
I had a few issues with the F18 after 4 flights and i have contacted the manufacturer to solve it out as the other F18 flies on the rails and could not figure out why the difference.
