Reload this Page >
Yellow aircraft f-14 biuld
Old 02-02-2015, 01:45 PM
  #51
Tempest-RCU
My Feedback: (98)
I'm definitely in for a set of pins and bushings. Let me know if you still need the various tracings we discussed. It's my plan to try and get to that this weekend.
Thanks!
Paul
Originally Posted by 70 ragtop
Got it
Have contacted a couple shops about making parts (CNC). Gene Barton is willing to make bushings, but only a couple (which works for me). Really need a head count to see if there is a need to make any more. I can sketch them up and post a scanned copy if that helps. Pretty simple if you have a lathe (that's running)
Focusing on just the pivot hardware this go around, brackets, pins and both bushings
Old 02-02-2015, 03:02 PM
  #52
70 ragtop
My Feedback: (24)
Thanks!
Paul
Hi Paul
I do!
I attached a PDF with a picture of what I need a couple postings ago. Stabs would be great as well if you can. I have the swing arms, if you still need them. Just PM me your address, or let me know you don't need them anymore. Vic really helped me out on the F-4, and I'm pretty sure you had a hand it that. My turn to pay a little good will fwd
Old 02-02-2015, 03:04 PM
  #53
Tempest-RCU
My Feedback: (98)
PM on it's way. :-)
Paul
Hi Paul
I do!
Old 02-02-2015, 03:05 PM
  #54
70 ragtop
My Feedback: (24)
Originally Posted by invertmast
If someone gives me photos with dimensions of everything, i can do a 3D solidworks drawing and have my machinist quote for the parts. Pricing is very reasonable and turn around is very quick as well, he doesnt mind small volumes either
same goes for wood parts, i only need a scan with dimensions and i can cnc cut those if needed
Thanks Thomas
Old 02-03-2015, 03:33 AM
  #55
tisdall_80
Originally Posted by MaHo
I have drawings!
Also a scan!
Regards Martin
I was meaning scanning the bulkhead/former drawings I have traced??
Let me know if you would like these??
Cheers
Old 02-03-2015, 05:41 AM
  #56
MaHo
MaHo's Avatar
Yes please scan them and share them here!
I will share what i have now.
Thanks, regards Martin
Old 02-05-2015, 01:10 PM
  #57
70 ragtop
My Feedback: (24)
Paul
Swing arms went out this afternoon
Here's a scan of swing arms for anyone who needs them. Rods end is a 10-32 male thread, #10 bolt thru the ball
Old 02-05-2015, 07:29 PM
  #58
70 ragtop
My Feedback: (24)
delete
Old 02-06-2015, 08:15 AM
  #59
dfhsy
How sad they stopped making the kit. Now they make nothing they import other than parts.
Old 02-06-2015, 01:06 PM
  #60
stevekott
stevekott's Avatar
Guys this is the controller board I used for my wing sweep.
https://www.pololu.com/product/1393
The original yellow board did a meltdown on me on the bench.
This contraption allows you to take a regular servo input (Pulse Width Modulation) from the Rx and control your wing sweep like a giant servo.
You need a feedback Potentiometer to keep track of the wing position. I used the same 5K Pot that was in the original wing sweep mechanism.
You can configure this board with a PC to program speed, endpoints, overloads and a number of other functions.
Hope it helps,
Steve
Old 02-07-2015, 09:15 AM
  #61
70 ragtop
My Feedback: (24)
Hope it helps,
Steve
Very interesting!
I like the worm gear setup on the Yellow servo, makes it almost impossible to overcome the servo. That said, they are a rarity these days, and if you find one, they're pricey. Couple guys have been using a Robot zone servo from servo city with good results. Fio used one on his EDF F-14, and Bullet also did on the FEJ F-14. Doesn't have the worm gear design, but does have some very high numbers at 180 degrees of rotation
https://www.servocity.com/html/robotzone_servos.html
Old 02-07-2015, 10:11 AM
  #62
FenderBean
FenderBean's Avatar
EDFJim had a FEJ F-14 with his own design that used a servo like this you may contact him and you can do a search on RCU and finds a few picks of his design. It worked great.
Old 02-10-2015, 02:23 AM
  #63
WimB
WimB's Avatar
Hope it helps,
Steve
Hey guys,
This would also be a good alternative to the Original controller board in the Skymaster version I guess.... I'm not particulary satisfied with the way the Original electronics work.... will need to check it out!!
Old 02-16-2015, 06:10 PM
  #64
Tempest-RCU
My Feedback: (98)
Mike,
You are the man! Thanks so much for these! For some reason I was not getting alerts when updates were posted to this thread. I believe I now have it fixed. Now to find those 10-32 ball ends and the wing pivot bushings...
Paul
Paul
Old 02-16-2015, 06:29 PM
  #65
70 ragtop
My Feedback: (24)
Anytime Paul!
McMaster Carr for rod ends
I sent a few PMs out to those who said they were looking for parts. Have been working with Charles to get any remaining F-14 stuff that may be kicking around the factory, made available for purchase
For anyone needing pivot brackets, bushings and pins, there are new sets available, direct from Yellow $240. Can also buy retracts $990, wheels $180 and brakes $120, all brand new right from Yellow.
Call Charles to order
Martin
I emailed you, just let me know which pieces you need drawings/dimensions of, and I will be happy to help anyway I can.
Old 05-01-2015, 05:34 AM
  #66
70 ragtop
My Feedback: (24)
Too bad this thread went dead!
I'm going EDF route with twin JF-120s. Received gear, wheels, brakes, and few sets of tires, swing wing brackets, pins, bushings, a full set of flying surfaces, bunch of misc glass parts, ect, ect. Thanks to MaHo, and Tempest, have the tracings I need to cut missing wood pieces, so I now have everything start building. I have 2 kits, and I'm thinking of building one with two sets of wings, a set of light weight wings (no flaps or spoilers) for initial flights, and maybe for everyday flying, and a scaled out set.
To that end, spoke with Don at Eureka, and he will be cutting cores, After I send him a set to copy, he will be able to cut cores for anyone else who needs them
Still hoping this thread starts showing some life, if not maybe I do my own thread on the other site
Old 05-01-2015, 02:12 PM
  #67
tisdall_80
I started doing a little work last night on my Tomcat last night.. In the process of glassing in the main bulk head and designing rear main retract mounts as there were non included in the kit I have. One main retract is not straight (bought second hand) so will need some attention to get it right.. Might just bite the bullet and buy a new set..
Old 05-01-2015, 02:38 PM
  #68
70 ragtop
My Feedback: (24)
Call Charles, he has one partial main retract (no strut) in his box of goodies. I don't remember if its a left or right, but it's new.
Old 05-01-2015, 11:00 PM
  #69
ticketec
Andy,
I've got a lathe at home if that will help to straighten it out. failing that, there are some more capable equipment at work, so give me a yell if you need a hand with it.
dave
Old 05-20-2015, 04:55 PM
  #70
70 ragtop
My Feedback: (24)
Any more progress?
Just finished up one project, so F-14 is on the bench.
ID:	2097388   Click image for larger version
Old 09-27-2015, 12:14 PM
  #71
agent adds
Has anyone got any photo's of there turbine installation-I am struggling for room.
Old 05-12-2016, 10:11 PM
  #72
tisdall_80
So after a long break from the Tomcat I decided it was time to get back into it.. Decided to make a couple of extra formers to add strength. These will run along side of the inlet ducts and attach to main Former.
ID:	2162233   Click image for larger version
ID:	2162234   Click image for larger version
Old 11-25-2016, 11:22 PM
  #73
tisdall_80
More Progress..
I have two Tomcats now.. Busy installing turbines etc into the second one.. Will test fly in undercoat and then paint once its a proven thing..
ID:	2191276   Click image for larger version
ID:	2191277   Click image for larger version
ID:	2191278   Click image for larger version
Old 11-26-2016, 10:38 AM
  #74
SECRET AGENT
My Feedback: (18)
SECRET AGENT's Avatar
Very cool, great work. Keep updating us as you go please.
Old 11-27-2016, 01:30 AM
  #75
agent adds
my model is totally finished but too date hasnt flown
Name:	golf and jag 058.JPG
