Unilight System
madmodelman (02-11-2020)
#77
Hi. i got the UniLight AFTERBURN-2-800 module but i dont understand how you program it propertly. . I use a unilight afterburner ring and when i plug in the battery 2cell lipo) it just light steady and low brightness. it does not change and do the flickering effect when i use the throttle stick. I tried to adjust the curve on the selected channel on the radio and so fort but the light doesnt change. No change when i switch modes on the module. Can anyone please help me? im stuck and need advice . thx
#78
My Feedback: (46)
Can anyone recommend some lights for me? I'm looking to outfit my T1, do I want 4w or 8w lights? I want 3 position lights, a landing light for the nose gear and a red beacon for the bottom, which do I need to get? The two position lights on the wings go behind some plastic lenses. Thx!
#79
There are a few choices of “kits” here: https://www.dreamworksrc.com/catalog...e+Lighting+Set
Pick the one you like or you can piece your own set together from individual components.
JS
JS
#80
My Feedback: (46)
I saw the kits at Dreamworks that's where I'm looking to order from, the kits won't really work for what I need to do. Like I mentioned I need to put the position lights behind the lenses and the kits come with the type that wouldn't work with that. So for a 2m jet would 8w or 4w lights be more appropriate or is it not that big of difference?
camss69 (10-27-2020)
#84
Nick, other than saying, look at the lights included in the kit and see if they will fit your application and if not, look at the stand alone lights and get the ones with the dimensions that fit.
Other than that (LOL!), I'd say get 8w, brighter is better!
On my ultrabandit, I bought a stock "sport jet" kit and used the 4 channel controller and have been more than happy with that set up. On other jets, I've usually pieced together lights and controllers (usually the 8 channel to program).
#85
My Feedback: (46)
Gives an idea on how the lights look. Video shot by Trevor who built the jet and installed the lights 👍
https://youtu.be/WpZHWL6C8Wk
The light illuminating the logo on that Havoc looks awesome too!
Could you post an up-close pic of your wingtip lights how they are installed? Thanks!
#86
My Feedback: (46)
#87
Thank you! That’s exactly the info I was looking for. On your wing tip lights did you put the stock plastic lens (the one’s that come with the plane) over them or did you leave them off for cooling? Can you run just the nav’s with the strobes off on the wingtip lights if you want to? The light illuminating the logo on your Havoc looks awesome too!
#88
Pics of the light install ... Hope this helps.
I have the 8 ch controller and you can program it to do whatever you want. It take a little bit to figure the programming out but you can do quite a lot with it once you understand it.
The lights are one of my favorite features of the jet ... I went high end lights instead of a smoke system. Don’t regret it at all. Mine was pieced together...not a pre-packaged kit.
The lights have quite large heat sinks on them. The ones I have also have over temp protection.
#89
My Feedback: (40)
I just used the "Large Jet" set and added an extra red beacon on the bottom for my Havoc. Bear in mind, there is no real "mounting" method for these lights. You just cut a hole where you want them, fish your wires through and glue them in place. I used Goop so I could pry them out later if need be. The lenses are also just Gooped or silicone glued on. Not as nice as Jamie's but these photos give a little idea of how I did mine.
#90
My Feedback: (40)
#92
Honestly, the only problem that I have is that I like to fly just before dark and the landing lights are blinding they are so bright at that time of day. I like the brightness during daytime though. I’ve thought about putting a light diffuser on the landing lights but usually remember this when I’m on final with the blinding light in my eyes. LOL!
#93
My Feedback: (30)
I just want Nav lights on the wings, red and green, and a beacon on the bottom. Just for daytime flying on some of my jets. If I buy the 4 channel controller with them, will that keep the strobe off if I want? I would like to just keep the red and green on constant without strobing. Would appreciate any help..
Link to the lights I am looking at:
https://www.dreamworksrc.com/11mm-du...x2-green-white
#94
My Feedback: (40)
#97
My Feedback: (64)
If you don’t need both lights, maybe check out a single light like this
https://www.dreamworksrc.com/uniligh...ight-7mm-green
or https://www.dreamworksrc.com/uniligh...ght-11mm-green
But yes, otherwise just use the two wires needed for the light you want to use
#98
My Feedback: (46)
Yes, you can do that. The way to keep the strobes off is to not connect the strobe wire to the controller. You will notice, it's a 3 wire connection to the unit you linked. One is a common, plugged into the 2-pin Nav connection on the controller, along with the Nav "hot" wire. You would normally, just use one pin/wire for the strobe connection. In your case, just don't attach the strobe wire. You may have to experiment to determine which wire is Nav and which is Strobe, but that's easy to do.
i ordered all my stuff last night from Dreamworks. Looking forward to getting it installed!
#99
My Feedback: (30)
