Coiled up airline? >
Coiled up airline?
Coiled up airline?
Old 01-10-2015 | 12:09 PM
madmodelman's Avatar
Default Coiled up airline?
Anyone know how to get the coils out of poly airline when it's been packed for a while , just like to get it straight and neat.
Gary.
Old 01-10-2015 | 02:28 PM
Place a length of metal wire(weld wire, all thread, music wire etc.) through the tubing marking the surface inside of the circle. Take a heat gun and heat that side of the tubing it will expand and when left to cool it will stay straight. This time of year I just put it on my mantel and let the wood stove do the work. If you don't have a length of wire long enough you can hang a weight on the end and use the heat gun in the same fashion. It's pretty tough plastic but a Monokote gun can overheat it if you stay in one place too long.
Old 01-10-2015 | 03:56 PM
That's great, thank you very much for the info,
Gary.
Old 01-11-2015 | 07:15 AM
JSF-TC's Avatar
Dump the coil in a container of hot water (just off the boil) to soften it, and then pull it straight while it cools.
Paul
Old 01-11-2015 | 01:32 PM
Thanks Paul, tried that this morning using boiling water, worked great.
