Reload this Page >
New big Ripmax Xcalibur (Xcalibur+)
Old 09-18-2016, 05:08 AM
  #476
Si_B
Si_B's Avatar
No problems today, had a couple of flight with no issues. I think I'm carrying a bit too much speed as she just floats in but will get the hang of it.
Flies nice, loads of grunt from the 140 turbine. Much easier to see in the air.
Simon
Old 10-03-2016, 12:36 AM
  #477
JP-1
John Cooke (JEC TEK) displayed his Xcalibur + at Long Marston over the weekend, all the previously film covered components have been fibre glassed in light weight cloth, John has also fitted lighting to the under wing stores. Note the shape of the cockpit is also different.
The model is finished in a hi-vis colour scheme
Alistair Powers
Name:	P1040259 (1024x768).jpg
ID:	2184248   Click image for larger version
Name:	5J5A5886 (1024x725).jpg
ID:	2184249   Click image for larger version
Name:	5J5A5895 (1024x726).jpg
ID:	2184250   Click image for larger version
Name:	5J5A5897 (1024x726).jpg
ID:	2184251   Click image for larger version
Name:	5J5A6064 (1024x683).jpg
ID:	2184252   Click image for larger version
Name:	P1040245 (1024x768).jpg
ID:	2184253   Click image for larger version
Name:	P1040247 (1024x768).jpg
Dansy (07-01-2020)
Old 10-03-2016, 12:41 AM
  #478
Jannica
Howe very nice! I like the colors.
Old 10-03-2016, 01:02 AM
  #479
JP-1
Not too disimmilar to the Saab J21R fitted with a DH Goblin turbo jet engine
Alistair Powers
Old 10-03-2016, 01:43 AM
  #480
Jannica
You are right about the J21R. But the Swedish air force never had that felling for combining colors!
Old 10-27-2016, 01:18 PM
  #481
sengle
Default Lights in Wings?
Hi Guys.
Has anyone put lights in the wings? It looks like the end of the wing is solid for a couple of inches so not sure how to mount lights and run cables back to root?
Cheers from New Zealand
Steve
Old 10-27-2016, 08:38 PM
  #482
richbran
richbran's Avatar
Steve, I have added a set of Unilight.at lights (somewhere in this thread), that include NAV lights in the tips. Indeed they are a block of balsa. As I have installed very powerful double LEDs (i think 2 X 8W), that require the version with a large cooling plate, I made a deep slot into the tips that was wide enough to house the cooling element plus have some air around it. The base droplet sized plate covers the hole.
Indeed You have to dig through a few centimeters balsa, but once Y're through, You can easily route wires to the root, as all ribs are open structured.
If You like I can mail You the setup I ordered with them (superb service!), but it can get costly, but even in direct sunlight they are good to be seen.
It consists of red/green tip lights, two headlights in the front of each boom (iso one in the nose), a flashing red beacon light on top mid of the stab and a white anti coll light on the bottom of the fuse.
Old 10-28-2016, 12:57 AM
  #483
madmodelman
madmodelman's Avatar
I did it the easy way, nav's on boom sides, strobe on rear fuse below turbine, rotating red beacon under belly, two 10 mm spots in leading edge of wings just outside booms. Five minute job. Iirc the wingtips have a ply plate sandwiched inside balsa blocks.
Old 10-28-2016, 01:12 AM
  #484
madmodelman
Pic.
Old 10-28-2016, 09:03 AM
  #485
richbran
richbran's Avatar
Steve, here You see part of my lighting system, it really helps with confirming the actual attitude and bank with less than optimum vis or a bit far out:
http://www.rcuniverse.com/forum/rc-j...l#post12187737
Old 10-30-2016, 01:13 PM
  #486
sengle
Thanks guys. I already have the Brain-cube lights from another model that I will be putting in. Cheers
Old 12-03-2016, 08:19 AM
  #487
Turbine63
Originally Posted by Dave Wilshere
Bo
Other than the mention of electric gear, super. The gear is pneumatic.
Best Regards
Dave
Hi Dave, I'm a newcomer to this forum and to the Jet world. I have quite a few decades experience in aerobatic and helis though. Since I never had to deal with a pneumatic gear. With how many PSI do I need to pressure the air tanks?
Old 12-03-2016, 08:47 AM
  #488
JP-1
Between 70psi - 90psi is good.
Old 12-03-2016, 10:14 AM
  #489
Dave Wilshere
Valve choice has a slight influence, but JP-1 is about right, with the individual valves supplied with the gear, 90 on gear and 70 on brakes is about right. On the combined Behotec valve we like to use I put 95 psi in the linked tanks.
Dave
Old 12-03-2016, 11:00 AM
  #490
Si_B
Si_B's Avatar
Make sure you check the pivot screws on your undercarriage. Took mine out tonight to check after 4 flights and they were very loose and one was hanging out. Undercarriage was put in by previous owner so should have checked but luckily for me it hasn't caused an issue.
Simon
Old 12-03-2016, 01:33 PM
  #491
Turbine63
Thank you!
Old 12-03-2016, 01:34 PM
  #492
Turbine63
Dave, thank you for quick response. Can you get me a part number for the BEHOTEC valve. Can't find it on their homepage.
Old 12-03-2016, 02:55 PM
  #493
richbran
richbran's Avatar
After quite a while quiet I have absolved four flights today. The conditions were absolutely tremendous: no wind, clear skies, high (if any) cloudbase. It wasn't cold at all.
I have concentrated to get my final speed down and if finally worked. With flaps I have auto trim compensation on the elev. Works great but tends to keep the speed up. So today, after practicing at altitude I have reduced my baseleg and final speed. After selecting flaps on downwind I have reduced the speed dramatically and dialing in quite some UP elev trim to compensate for Lift loss.
That brought my speed very well down. I tried to keep that lower speed till close to the ground. It worked.
Here's a piccie that shows the high alpha. Note the toe-out rudder position to add more braking.
Yes the gear has its shortcomings and needs careful maintenance, indeed the screws and pivots
ID:	2192129   Click image for larger version
ID:	2192130   Click image for larger version
Old 12-05-2016, 03:21 AM
  #494
richbran
richbran's Avatar
Sunday I did a re run of Saturday, slightly more wind but with good thermo overalls no issue. Landings are much easier with lower speeds. But there is a large UP trim change needed to accomplish a lower speed. This cannot be dialled in automatically with flaps, as the plane would climb.
Another phenomenon I noticed is the difficulty to make a stall turn. (that is, not all jet pilots want to do stall turns).
As a (model)glider pilot I know all gliders are more difficult to stall turn than (prop) powered planes, as the latter ones continue to blow air over the fin and rudder. Aerodynamically jets resemble gliders better than prop powered planes.
The mid placed engine/exhaust does not help either in my opinion.
Related is the effect in bank angle with rudder. It almost does not roll with rudder. It merely skids. Only maximum rudder will move the bank somewhat.
I reported in a former posting that knife edge flying requires same direction aileron correction, as opposed to single fuselage models that require cross control correction.
I figured out the even displacement of rudder might cause this, in my next flights I will start some testing with "differential" rudder displacement, ie, in a left turn more travel on the "inboard" rudder as the outboard, and vv with a right turn. Like the front wheels of a car do in a turn.
Gear:
Again more and more play on the lower part of the main legs around the pivot point. The pivot system is under designed, I am contemplating to replace the gear with a Behotec or likewise system. Wheels and brakes are great however.
The plane has now some 40 flights.
Everybody likes it's in-flight silhouette and low speed handling!
Old 12-28-2016, 12:55 AM
  #495
Dave Wilshere
Just finished another Sports scheme Plus for customer and friend AP. Model uses a JetCat P-140Rxi, JR XG-14E DMSS system with JR 331, 579, 8421 and 8411 servos. MAP Hi-Flow bubble trap. AP also wanted a Powerbox iGyro3e and JetCat mini GSU installed, lastly a landing light.
Few pictures of the build.
ID:	2194599   Click image for larger version
ID:	2194600   Click image for larger version
ID:	2194601   Click image for larger version
ID:	2194602   Click image for larger version
ID:	2194603   Click image for larger version
ID:	2194604   Click image for larger version
ID:	2194605   Click image for larger version
ID:	2194607   Click image for larger version
ID:	2194608   Click image for larger version
ID:	2194609   Click image for larger version
Old 12-28-2016, 01:30 AM
  #496
DenisFerrari
Very nice job Dave!
...could not be different
Old 12-28-2016, 03:14 AM
  #497
Dave Wilshere
Finished and collected. Denis :-)
ID:	2194612   Click image for larger version
ID:	2194613   Click image for larger version
ID:	2194614   Click image for larger version
ID:	2194615   Click image for larger version
ID:	2194616   Click image for larger version
ID:	2194617   Click image for larger version
ID:	2194618   Click image for larger version
Old 12-28-2016, 11:42 AM
  #498
JP-1
Well pleased with it D, I like the sports scheme on the Xcalibur Plus, a little Italian flavour I think.
Alistair
Old 12-28-2016, 11:56 AM
  #499
Dave Wilshere
Yes, idea came from my Angel S, one of my favourite schemes.
See you Friday
Old 01-02-2017, 07:19 AM
  #500
Dave Wilshere
Another Xcalibur Plus sports scheme finished. This was Paul's first turbine build, two faultless flights today, I hardly needed any trim. JetCat P-140Rxi and JR radio throughout. Paul triumphant after his first flight!
ID:	2195220   Click image for larger version
ID:	2195221   Click image for larger version
ID:	2195222   Click image for larger version
ID:	2195223   Click image for larger version
ID:	2195224   Click image for larger version
ID:	2195225   Click image for larger version
