Ripmax xcalibur. Gyro? And which one?
Hello all.
Im working on my xcalibur and have an extra Igyro and new igyro 3e available in my parts bin.
Should I put one in?
suggestion on which one?
With either one I plan on using a matchbox for the rudder servos.
Thanks in advance!
Thanks in advance!
You can fit the iGyro 3e. A Y lead on the rudders is all that is required if you set the servo arms square mechanically.
Like Jim says the Xcalibur does not need a gyro, but it will make it very smooth.
Dave
Dave
Hi
If you are thinking of fitting the iGyro 3e take a look Xcalibur thread post 1164 I said how I got on with the 3e. I have taken it out of the Xcalibur as I could not get it to work.
