Nose Wheel Steering
My Feedback: (7)
Did you use a mix to also provide steering, such as Rudder -> Steer(AUX5?, etc)? If so, only enable it when the gear is down. There is generally a switch used to enable a mix, simply use the gear switch, in the gear down position to enable the steering mix.
An alternate method to disable a function would be use a Steer -> Steer mix with a value of -100%, in this case, the disable steering mix is enabled by the gear switch being in the "gear up" position.
Depending on how you have your steering setup you would only need one of these mixes, not both.. I don't own an XG14, but assumed it's pretty similar to my 12X so I hope this helps..
Cheers, I should have mentioned as im using a 7channel RX, im using the xbus system and the nose wheel servo is a "sub id" to the rudder channel. so the main rudder id is 4/1 & steering servo is 4/2 i need to inhibit 4/2 when gear switch is in up position
