JL YAK130 TWIN maiden
Hi guys
Hope you enjoy.
The maiden went very well. The only problem was the front main gear that colapsed in the 3th flight with a very smooth landing. The king pin was not tightened in the factory and I put my faith in their job.....
The plane is so smooth that I already miss a bit of adrenaline ;-)
https://www.youtube.com/watch?v=Kq8nsQfOX-I
Regards
Nuno
Hope you enjoy.
Regards
Nuno
Jets edu (07-03-2022)
Nicely shot video, Smoothly flown, congratulations on your first flights and wish you many more.
You certainly got better weather than us guys in the UK this weekend, cold and gusty
I look forward to you sharing your findings on CG, movements and flap-to-elevator settings as you fine tune it over these first flights.
Hi all
Thanks for the kind words.
My set-up is
CG - where signaled by the manufacturer
Throws
Elevator 50mm high rate 35mm low rate
Ailerons 30mm high rate 20mm low rate
Rudder 20mm measured at top
Flaps high rate - all that is allowed by the flap rail (110mm) Low rate 50mm (not used)
The plane is very smooth - only 1 click in aileron and 4 clicks in elevator. A bit of flap adjusting was needed because when lowered it was slightly turning right. There is a need for a flap/elevator mix. Arround 3mm needed.
Next step is to make a throtle /elevator mix, because at full throtle it tend to go up slightly. Maybe I can put some more down thrust in the turbines, but the first seems easier
I found this bird to be tooooooooo slow for me. I was a bit bored....Not for the F adrenaline junkies
Best regards
Nuno
My set-up is
Throws
Best regards
Nuno
Congrats my friend, I hope see you soon.
Regards from Spain.
Carlos.
________________________
www.cmjets.blogspot.com
Regards from Spain.
Carlos.
Bonjour Dorien
I have arround 600gr in the nose, but it is nose heavy, so I will remove some.
Dependeing on the set-up, you will need to add more or less weight. I have 4x 5000mAh batteries, an opneing canopy and a pilot. These will add some weight up front
Is it yours a twin?
Regards
Nuno
Is it yours a twin?
Regards
Nuno
Hi
Very smooth maiden, congrats! Do You know where you have the CG now? I have heard it is way noseheavy with factory setting. I was told i need to move the CG 7-10 cm back. This Means CG will be on the main wing tube.
Best regards
Christian
Best regards
Christian
Hi
I started where the manufacturer signs it, but it is way too nose heavy. I am moving it backwards by arround 10mm. Maybe someone with more flights can update
Best regards
Best regards
Ok, Mark Hinton from UK told me to move it 70 to 100 mm backwords. He has flown three different J L YAK 130, and all three needed to put CG back, but all three needed different CG???
Hi Azhar
Yes. It is along the paint line. There are 2 build threads in rcu if you look arround. I am moving backwards the CG. Had some troble with leaking door cilinders, but now it is smooth
I found at full throtle the plane as tendency to climb. I guess that as to do with the high speed ventury effect under the stab. I am planning to make a small mix at full thrtle with down elevator.
What do you think? Here is a link
https://www.youtube.com/watch?v=_SKBZuBxAJw
I would say at arround 1cm behind where signaled by the manufacturer. Y will change the batteries for lighter ones and come back after measuring CG
Br
Br
