Pst phanter jet
Pst phanter jet
Any one has any experience with the pst panther f9 ? There is little to no info on their website.. I need to know if it would fly on a jet cat p-60 ??
Any info ??
Any info ??
I have had one for about 6 years and love it. I have many many flights on it. Mine has a P-70 and flies great on it. I think a P-60 would be a bit lacking for this jet especially if you put any stores on it. Mine has 6 of the 2.75" rockets on it and that adds a lot of drag. (see my avatar). I did not make the body flaps or speed brakes operational on mine to save weight and reduce complexity and it is a great every day flyer. Hope that helps.
Panther
Approx 3 yrs. ago I saw a Panther fly at Ft. Collins with a 12lb thrust engine. It flew very scale like. I don't think it was a PST but weighed approx. 25lbs at take off. In Co. Springs you will probably have a higher density altitude. I would consult with the turbine guys in the Pikes Peak club..
Greg
I forgot to mention I flew my 1st Ziroli Panther with a Ram 500. 12 lbs of thrust. I couldn't tell the difference between the Ziroli and the PST with the Wren SS wit hover 15 lbs. Both flew at about the same speed . I think there is just so much drag with that airframe it will only go so fast.
