smoke nozzle placement on p70??
My Feedback: (38)
okay I have a question for you fellas, I recently picked up an elan that has a p-70 in it I also got a smoke setup for it with the Jet tech partitioned tank and a tamjet smoke pump with twin nozzles, but I am confused as to where to place the nozzles. I have always read that you try to get the nozzles in the center of the turbine outlet however, the p70 has a weird tail cone it has an inner cone as well as the main one and I'm not sure if I am supposed to try to put the nozzles in the center of the little cone in the middle or just try to get them in the flow of the main cone any help on this would be appreciated I have never seen a turbine with an outlet like this
I have a Wren 160 on my KIngCat and only use one nozzle.( I know your engine is smaller but I am sure they both get just as hot.) I have it mounted on the top with the tip just inside of the hot flow, so as not to shoot any fluid on the airplane. Works great, I get all the smoke I could want.
My Feedback: (57)
Ha ha Ronnie, that is actually a cool spot on the engine exhaust (just downstream of the tailcone, where air tends to separate), still pretty hot, but I would cut out the tube about .5 - .75" , that would spit it on the area where the hottest expanding gas is.
but then again, what you have is probably good enough. :-)
David
David
My Feedback: (38)
David,, thanks I did not know that center was the cools spot,,, the little cone on the p70 is just weird,, wonder why its like that, I will move the tip into the main exhaust on the outside of the cone and try that and see if the smoke is any better,, good thing Is I can just grab the smoke tube and bend it back a little bit and then back towards the cone...looks cool with the smoke, I like it..I have actually had a lot more fun flying it it than I thought I would. I will be at the Houston Jet rally Friday morning,, You gonna be able to make it??
I know that Gasper has not used them on the VT 80 or the M140.. But he has included them on the new M 200. I guess that not all model engines benefit from them..
Disclaimer:: I am very much an amateur turbine enthusiast.
My Feedback: (38)
Also For details, I am using a Sullivan skywriter smoke pump (same kind I use in my aerobatic planes) and a 1000mah 2s lipo battery to the smoke pump, I have this same setup on a 1/3 pitts and easily gives 2 flights with smoke before needing a recharge and the batt weighs next to nothing,, Nozzle is a piece of stainless that I crimped the end of, first using a set of pliars to flatten the end Not quite closed, then taking a pair of side cutters and crimping the middle of the pipe, sealing it up making two small sprays at the end of the tube...
My Feedback: (57)
I'll have a crack. My understanding, is that the exhaust cone functions to control the gas flow as it leaves the turbine disk. It covers the solid part of the disk and creates a nice flow path between it and the outer exhaust nozzle. Thus reducing turbulence in this area and increasing velocity and thrust. Most full size engines uses some kind of exhaust cone, although it seems many model engines don’t feature them.
