PB Competition SRS and futaba again
My Feedback: (95)
I know, this has been talked about before and I have done some searching on the topic but I am tired of trying to piece it together. What is the latest info on this combo? Are people using it without issue right now? Has anything been discovered/resolved? I would like to use the Competition with two 7008SB receivers. It is such a clean setup. PM me if you don't want to say anything public.
Absolutely perfect. Between myself and a friend we have 20 jets flying with that combination. Never had an issue on 14MZ or 18MZ.
Cheers,
Jan
Same for me as well. No issues at all using R7008SB and R7003SB with P/Box Competition SRS and Cockpit SRS.
Actually its a perfect combination but ensure you operate one R7008SB RX on Channel Mode B and the other on Channel Mode D, which utilizes "Full Redundancy".
Patch Leads to RX1 and RX4 on the P/Box (make sure they are connected to S-Bus on the RX), and NOT S-Bus2.
Then all I do is MAP the P/Box channel output to suit my T18MZ function, and set-up the Li-Po capacity (m-Ah).
And finally ALL telemetry connections through S-Bus2.
Never heard of any issues until I saw a previous post from Erik (sorry for your loss Erik and look forward to any updates).
Ilkka
