what are some of your favorite Grass runway jets
My Feedback: (34)
Ok I'm in a odd situation
I'm in the Army currently in Columbus Ohio. I just got orders and will be gone around the middle of June.
My current field is grass and stays to soft to fly turbines until July
But I build a Velox XL this winters and only got 4 flights on my F15 before the first snow came.
There are only 2 hard top runways within 2 hours of my place in Columbus Ohio that I know of. One with a 2 year wait list to join, and the other with a very long and $ member ship program
So I'm almost tempted to buy another jet just so I can get some flights in before the Army makes me leave, it's been such a long winter
I currently own a Carf Rookie 2 with P120sx I thought of putting some soft fat dubro Tires on but the fear is always the nose wheel digging in the soft ground on landing
That is what happened to my Carf Eurosport the front nose gear dug in until the front intake plowed some earth. Luckily no damage but to the runway
So what options out there for softer runways?
I say a vid on YouTube of a Buda USA Northstar with turbine taking off on water. We do have a nice lake
Thanks.
Mr can't wait anymore Mike
Thanks.
Our field is a flood plain, it is almost always very soft as it is just inches above the surrounding swamp. Even when it is not under 6 feet of water (Most club members have floats or boats for when the field is a lake) it takes a long time to dry out. My Reaction 54 from BTE with a P70 handles these conditions just fine, even when the field is so soft that it is hard to walk on without getting your feet wet. Just use the biggest diameter tires you can get away with and build to use trailing link struts. There is usually mud kicking up off of the wheels during take off, landing and taxiing, you will want an aircraft design that has the turbine intake well shielded from FOD. The R54 has the turbine mounted above the wing at the trailing edge so it is well protected from wheel spray. Anything with an air intake below or even on the sides but down low can be bad for the turbine.
My Feedback: (76)
Sport Jets without gear doors and large wheels will be your best bet:
1) Pirotti Tuono
2) 2.5 M Futura
3) Shockwave
Scale jets will generally have a hard time unless they are very big like the skygate hawk, or large tomahawk
1) Pirotti Tuono
2) 2.5 M Futura
3) Shockwave
I have a Q Composites Aurora, it has 3.5" nose and 4.5" main wheels and works great off grass.
My Ripmax Xcalibur works well too, mainly because its light, i think it has 2.5" nose and 3" mains.
The Ultra Flash works well to with there standard gear... and a jetlegend L-39 would work too, its gear doors are closed while the plane is on the ground.
https://www.youtube.com/watch?v=g2Wgs8atiEM https://www.youtube.com/watch?v=y_wodYawE7E&feature=youtu.be&app=desktop
Fitted big tundra tires to his Boomerang & left the SpringAir retracts without air.
John.
NM
Don't know if anyone is interested but I am about to list my reaction 54 for sale. I have reached an age "mid seventys" that I don't trust myself to fly jets anymore. My reaction 54 is the full composite, yellow and blue jet that is like new. Has a mt80 full in case kerosene start that has TWO flights. Has a 14 futaba receiver that has TWO flights. The jet flys wonderfully and has plenty of power with the 18 plus turbine. Just put a new robart rear sprung nose gear on as the original was to soft for my liking. Guys, I have a five degit ama number and this jet is set up immaculate. Will sell with a futaba 12fg ready to fly for 3500. Will drive up to 300 miles to meet someone. Kenny Cross, Las Cruces,NM
My Feedback: (12)
I have flown every turbine powered jet I've ever built off grass and some others listed below, none had any trouble with the grass fields.
BVM Bobcat XL,
Reaction 54
Roo
Turbinator std and 125% sizes
AV8R
Facet 2300
Shockjet
Boomarang
BVM Bandit
BVM small f86
yellow small f-18
Starfires
BVM Bobcat XL,
Reaction 54
Roo
AV8R
Facet 2300
Shockjet
Boomarang
BVM Bandit
BVM small f86
yellow small f-18
Starfires
I flew my Boomerang and Falcon 120 off grass, but with fixed gear. My CARF Lightning has also flown off grass, after fitting trailing links, but only dry firm grass. It is much too heavy for soft ground, and I would never risk my Eurosport or Gripen on grass.
So I designed my own sport jet, I call it JayTee, and stuck with fixed gear using 4 inch mains and 3 inch nosewheel on a short glass fibre U/C to reduce the pitching moment of the wheel-drag.
It flies off long grass, wet grass, short runways, whatever, far better than even the Boomerang or Falcon 120.
I even fitted floats which are great for flying off water, or hard snow.
Like the Boomer & Falcon, JayTee uses a Wren 54.
So go for something simple and versatile with fixed gear and big wheels.
