Dreamworks Heat Shield
Has any one tried this heat shield that Dreamworks sells. If so how did you like the results
http://www.dreamworksrc.com/catalog/...-1-12-X15-Roll
Paul Appelbaum
Paul Appelbaum
Works good. I thinned mine a bit to make the coating thinner on the model. But, it has held up well and fully protected the model. It does add a little weight. Aluminum tape would be lighter. But the tape does not get down in the tight spots as well.
I got some of the cloth also. I ended not using it because I still wanted air flowing thru the area that I planned using it. Also, fastening it became an issue. I ended up only using the cloth to shield my horizontal stab for startups. But ultimately I put some alum tape on the bottom of the stab cause there really was not much flame on any of my starts.
I thinned the BVM Heat Shield using some water.
