Reload this Page >
Sebart Mini Avanti w/ K45 build thread
Old 09-27-2017, 05:43 AM
  #551
stevemcclintock
Are they better than stock?
Better or as good as Tam?
Old 09-27-2017, 05:47 AM
  #552
Dave Wilshere
Better than both I'd say. The material is the best available, not some soft excuse for aluminium alloy!
Old 09-27-2017, 05:55 AM
  #553
josex
Originally Posted by Dave Wilshere
J125.1037 made by Jet-1a. They are doing sets for the Mini Avanti
email them at [email protected]
It looks a bit to short or is it just the picture?
Old 09-27-2017, 06:44 AM
  #554
Dave Wilshere
That was just a test example from a Savex L-39. They are making specific units, right size top hole etc for you guys
Old 09-27-2017, 06:49 AM
  #555
Bob_B
Bob_B's Avatar
I have a set of Jet 1A gear it's top notch stuff, I have emailed them for pricing and availability.
Old 09-27-2017, 11:34 AM
  #556
c_makhija
Great news... if Jet 1A is doing a set for the Avanti. Excellent Quality.
Chatty.
Old 09-28-2017, 04:17 AM
  #557
BarracudaHockey
BarracudaHockey's Avatar
Anyone have a source for the pins for the Tam gear? I can get the main pins from McMaster Carr but there's no flats, which is possible to make by hand but if there's a source that has the flats in the right place that would be my first choice.
Old 09-28-2017, 06:26 AM
  #558
lorenb
are there any website of the jet a1 struts?
Old 09-28-2017, 06:58 AM
  #559
Bob_B
Bob_B's Avatar
just email Jet 1a
Old 09-28-2017, 10:35 AM
  #560
Dave Wilshere
Ask Sabine to send pictures or anything you need. She speaks perfect English.
Old 09-28-2017, 11:00 AM
  #561
Bob_B
Bob_B's Avatar
Hi Dave,
I have been emailing with Sabine.
Thanks for the tip.
Old 10-04-2017, 10:32 AM
  #562
stevemcclintock
Originally Posted by why_fly_high
A friend of mine that just got a 70 and has a full test rig. I asked him to test fuel consumption at 45 N thrust and check idle thrust to see if a K70 turned down to a 45 is better, equal to, or worse than just using a K45.
Any news on this testing?
Old 10-04-2017, 11:20 AM
  #563
Bob_B
Bob_B's Avatar
I have a set of the jet1A struts Coming for my mini Avanti as soon as I get them and have them installed I will post some pics
thanks for the heads up on these DW
Old 10-04-2017, 06:54 PM
  #564
why_fly_high
My Feedback: (19)
Initial tests showed near identical idle thrust and slightly less fuel burn at 10lbs thrust compared to K45. I have not heard their full throttle fuel burn. Full throttle output was as advertised.
Old 10-05-2017, 06:01 AM
  #565
stevemcclintock
I like the sound of that! I doubt with this plane I will be at full throttle much! I need the wings to stay on! lol!
I believe I will go with the K70.
Thank you...
Old 10-05-2017, 09:23 AM
  #566
stevemcclintock
How big of a front wheel can you put on these?
I would like to put on at least 2 1/4" to fly off grass. 2 1/2" would be nice.
Old 10-05-2017, 09:50 AM
  #567
Bob_B
Bob_B's Avatar
I won't know until I receive the struts, as far as I know it is just the mains they are selling.
Have a look at this strut for the nose gear. https://www.fantastic-jets.com/epage...ucts/025NLM100
Bob
Old 10-11-2017, 03:33 PM
  #568
a25afm
Default Mini avanti build
Here is the CG of my Mini Avanti build. I wanted to mount the fuel tank as far aft as I could. It’s still forward of the CG.
Has anyone calculated CG with full fuel? (1.3L CM jet tank)
Here are the CG calculations I came up with. 145 mm recommended. I figured that I should never see the empty CG in flight. Hopefully...
Full Fuel 138.3 mm aft of the leading edge. Total aircraft weight 189.9oz
Landing Fuel. 148.9 mm aft of the leading edge. 165.5oz
Empty Fuel. 152.5 mm aft of the leading edge. 160.0oz
Old 10-11-2017, 04:21 PM
  #569
a25afm
Default Mini Avanti
Here are a few photos.
ID:	2240931   Click image for larger version
ID:	2240932   Click image for larger version
ID:	2240933   Click image for larger version
Old 10-12-2017, 01:49 AM
  #570
ltc
Hi
i received an email from Maria at Electron Retracts
She confirmed that they will soon have the ER30 retracts and struts for the Mini Avanti
(these are the save units that first appeared on the new Pirotti Rebel Hot)
Very nicely built and designed units.
Old 10-12-2017, 02:12 AM
  #571
Bob_B
Bob_B's Avatar
Great to have an option. The std retracts have been flawless, the struts are definitely the weak link.
Old 10-12-2017, 05:20 AM
  #572
Fish4funjb
I see you have the tank from CMjets. I asked Carlos form there about purchasing one but odd that he needs a ID number from me? He said Italy uses this for tax purposes. They call it a National Document Identity?? I looked it up and it is like our social security number. I asked him if there is any other way because I cannot give him that. Did anyone else give this or am I mistaken of the ID he is asking for?? I need the 1.5L tank form him and the Itrap40 for my Mini Avanti S
Thanks, JB
Old 10-12-2017, 10:34 AM
  #573
c_makhija
Originally Posted by ltc
Hi
Electrons would be the best option, had tried to fit the ER 30s when I received the 1st prototype, but thought the 30s were a bit big and heavy for the Avanti, the 30s would be perfect for jets the size of the rebel hot.
Chatty.
Old 10-12-2017, 01:02 PM
  #574
jet-lover
Chatty.
Bit of an overkill but I put electron 30's in my 90 mm Taft Cobra foam jet as I got sick of continually buying cheap HK crap. It really is false economy to keep on buying the same item over and over again. Not only does this add up in money but every time I have to do a belly landing I risk damaging more things like ripping out control horns et cetera.
I fly off a grass runway and the electrons have been bullet-proof.
If I add up all the money I have wasted over the years purchasing cheap retracts, I could have bought many electrons.
Old 10-23-2017, 12:38 PM
  #575
tuxian007
Hello,
I already received the main and hopper tank from Carlos
Should the CG be set up with empty main tank?
So I've made it anyway with my Avanti S.
Markus
