JR12X Throttle position for smoke programming >
Old 05-22-2015 | 03:31 PM
My Feedback: (21)
Default JR12X Throttle position for smoke programming
I need some help. I have programmed my 12X in my ISOBAR Jet to run smoke on the throttle position setting in program mix 5. It turns my smoke pump on about 2 clicks over 1/2 throttle and stays on up to full throttle. What I can not figure out is how to turn that mix off with another switch. I don't want the pump to run when I run out of smoke oil.
Joe Lewis
Kingtech
K-80 and K-140
Owner
Old 05-22-2015 | 06:13 PM
My Feedback: (27)
Turn mix switch on in that mix 5(top right switch). That should allow you to turn it off
