Looking for a fuel pump.. >
Old 05-23-2015 | 06:43 PM
MJD's Avatar
MJD
Default Looking for a fuel pump..
.. that can flow about 1200cc/minute. So far replacment/accessory pumps I have found cap out at about 700cc/minute. Anybody know of one?
Old 05-25-2015 | 09:27 AM
HI.
TAKE A LOOK HERE!!
http://www.ullermann-kleinstfoerdert...index.php/shop
Old 05-25-2015 | 09:28 AM
http://www.ullermann-kleinstfoerdert...p/650er-pumpen
Old 05-25-2015 | 10:41 AM
MJD's Avatar
MJD
Thank you!!!
Old 05-26-2015 | 08:13 AM
My Feedback: (51)
HP-Tech makes some up to 1450 ml/min.
http://hptech.at/startseite/produkte/dc-pumpen/
Old 05-26-2015 | 08:30 AM
Mark Vandervelden's Avatar
Have you considered the AMT pump? I have one here put by to use as a high volume smoke pump some day. I'm told the actual pump part is made to a very high standard but although they look fancy like nearly all non digital turbine pumps it uses a std cheap brushed motor all be it bigger than most but in this instance hidden in a much nicer case. I'm not 100% sure of the spec but it might well cope with 1200cc/min as its quit a lot larger than most and believe its still used on there bigger turbines, just a thought.
Old 05-26-2015 | 11:54 AM
MJD's Avatar
MJD
I looked at AMT's website but could not find info about the pumps (maybe I did not look hard enough?),. The Olympus has specific fuel consumption around 720-730 cc/minute - I would assume the pump can flow more than that.
Edit: ok, I see the Titan now, it runs about 1200cc/minute. I'll inquire about the pump for it.
The Ullermen pump runs EU $113, about $160 CDN dollars, versus a locally available 700cc/minute pump @ $117 USD which is $150 CDN dollars - so for 10 bucks more I get an expensive German pump.
