Viton Tubing
Viton Tubing
I use diesel on my Rhino and i just sent it in for it's 25 hour maintenance checkup. I plan on removing the klunk lines from the tanks which have tygon tubing at present. I've been using viton on my gassers for 5 years now and have not had to change them yet due to viton getting hard. Iv'e researched online about viton and everything iv'e read says it is impervious to oil and gas. Has anyone had real world experience using viton in their tanks running diesel? Thanks for any info with your experience on this
Mel
Mel
I have been wanting to switch over from tygon for awhile since it gets stiff, but I cannot find viton in larger diameters to fit my hi-flow setups. Do you happen to have a place that has different diameters?
Hi everyone! Thanks for all your inputs and experience on the viton tubing. I'm going to put it in to my tanks tomorrow so my jet will be ready to go when i get my turbine back from Jet Central.Thanks again for your input
Mel
Mel
Well i just realized that the only viton i have is 1/8 i.d. so i just ordered some 3/16 and 1/4 id from McMasterCarr so i should be good to go! Fenderbean they have all different size's at McMasterCarr. The easiest way to find it on their website is to type in Viton in their search box and you will be taken to the right page. I allways use the soft viton
Mel
Mel
I purchased 1/4"OD 1/8" ID Viton from Mc Master Carr 3 times for myself and a few friends. The first and third time the tubing was slightly oversized. The oversized stuff I have in the tank my 1/4 scale Panther. It feeds diesel to the K-170 with no problem. It has been in there for three seasons and is still like new. The oversize is very slight. You might be able to see it in the picture.
What size turbine are you using the 1/8 id tubing on? I'm kinda worried about using the 1/8 on my Rhino. I think it might possibly starve the turbine of fuel. i don't think i could get the 1/8 tubing on the barbed tank lines either. Thats why i ordered the 3/16 and 1/4 id tubing. If the new tubing that i have coming is too big on the fittings i might have to use the 1/8 id Viton
The Viton I have is black ( on the ruler). The clear tube in the picture is a 1/8" OD tube that I was slipping the two different sizes of Viton over to feel the difference in size. The smaller size I need to push on with some friction while the slightly larger size slips on easily with a little friction.
The Kingtech K 170 burns 19 oz. a minute at full tilt. It seems to pull through the 1/8 ID Viton it the tank with no problem. When I pump the fuel into the plane to fuel the tank it is going through the same tubing at a faster rate than 19 oz. a minute. I don't think it takes 11 minutes to pump 200 ozs. on board
Mel
Mel
Yes I agree with you that initially it's expensive upfront but in the end i think it pays for itself! I was replacing the tygon in my gasses every 4 months due to it getting hard but since iv'e switched to viton it's been 5 years. It's nice not having to worry about it getting hard anymore!
My Feedback: (48)
There is one fuel line for gas, kero and diesel that works just as well as viton but costs 1/5 what viton costs. The line is just as bullet proof, just as flexible long term inside or outside a tank and actually much more abrasion resistant and stronger in tensile testing (which doesn't matter in reality since lines are usually not in tension). If interested, contact me direct to my address in my signature. I carry 1/8" ID for gas engines but all sizes available on request.
My Feedback: (33)
wonder if he referring to clear tygothane c-210. Good stuff, just stay away from the thin walled 1/32, kinks way to easy. ask me how I know!
