Need Help Finding Replacement FB MB-339 Brake O-rings
My Feedback: (20)
I need to replace the O-rings on my FB Jets MB-339 landing gear. There are two O-rings inside each brake.
They look like they are flat on the outside where they contact the wheel drum and round on the inside.
Does anyone have a source for getting these replacement O-rings.
Gary
Gary
My Feedback: (20)
They look like regular O-rings except they are flat on top. I think a round O-ring that would be wide enough to sit in the slot would stick out the top and prevent the brake assembly from fitting inside the wheel drum. I got the gear second hand but it came from FB Jets. I have been unable to contact them today.
Gary
Gary
My Feedback: (16)
Gary
Gary
K.O.
Gary, I have had success with McMaster-Carr. Just measure the O-ring and order the correct size from them. They have every size you would ever want. I'm pretty sure the flat top is from wear. I just replaced a set on one of my FB models.
http://www.mcmaster.com/#o-rings/=1134ezx
