Reload this Page >
New Composite ARF SU27
Old 06-25-2021, 09:15 AM
  #651
roydefiant
Default Flaps
We are flying mine with full flaps 5 cm down from fuse side of flap. In looking at videos some appear to be lowering flaps beyond this? I wonder if any issues blanking out tailerons?
thanks
Old 06-25-2021, 09:31 AM
  #652
TheFishLA
thanks
I wouldn't not recommend going below 5cm. I feel that with full flaps it's really hard to maneuver the plane. So going more than 5cm would probably make more turbulences.
In the beginning (before i got used to the 5cm flaps), I use to deploy the flaps only on final because it was so hard - the plane just wouldn't turn.
Old 06-25-2021, 04:14 PM
  #653
roydefiant
Thanks, makes sense
Old 06-25-2021, 08:46 PM
  #654
Dave Wilshere
We all use maximum flap angle SU-27 and 30, I don’t have a cm distance without checking, but it’s way more than 5cm-there is no blanking issue I have experienced in the SU-27 I have flown.
Auburn02 (06-28-2021)
Old 09-11-2021, 07:26 PM
  #655
roydefiant
The following 2 users liked this post by roydefiant:
TheFishLA (09-11-2021), yeahbaby (09-12-2021)
Old 09-22-2022, 07:57 AM
  #656
essyou35
Is there a thread for the su-30 version of this or is it the same jet? Im curious if its the best choice still as we have a skymaster version and now an aerojet version. A dual turbine jet with thrust vectoring is my dream jet and its time to get one going!
Old 09-22-2022, 11:37 AM
  #657
Dave Wilshere
Same thread. It’s a few mould differences with fixed canards. SU-27 vectors better…
Old 09-22-2022, 12:30 PM
  #658
essyou35
Are the gear reliable? Seems mig/su27 have issues in models. Id go with electric
Old 09-22-2022, 01:30 PM
  #659
Dave Wilshere
Gear is now electric…
Old 09-22-2022, 02:25 PM
  #660
TheFishLA
Yes. The gear is high quality and very reliable. Here's a demo of the new electric gear:
If you need more reason to press the 'buy now' button... check out this video. The CARF SU27/30 is way more maneuverable than the other brand:
Old 09-23-2022, 08:22 AM
  #661
essyou35
Anyone selling one before I order?
Old 10-11-2022, 09:44 AM
  #662
Ruven
My Feedback: (8)
Originally Posted by kmrcjets
I need some info on the new SU27 for a friend that has just received one. there is no info that comes with the model in regards to the suggested
servo's required or the centre of gravity measurements. we are hoping someone out there can supply this info for us. the dealer in oz does not know and comp arf do not seem to answer emails
regards
ken
i am flying mine.
[email protected]
Old 10-11-2022, 11:01 AM
  #663
Ruven
My Feedback: (8)
I could be interested
contact me at [email protected]
Old 04-27-2023, 02:52 PM
  #664
pfact
My Feedback: (92)
Default Thrust tubes not fitting into vectors
The outer diameter of my thrust tubes is a couple mm less than the inner diameter of my vectors (photo). Forcing the tube into the vector might be possible but would likely distort one of both tubes. Has anyone else had this same issue and if so what did you do?
Phil
Old 05-02-2023, 08:23 AM
  #665
skymaster68
Anyone with Down&locked LG has try another brand of controller?
I have a friend using the first batch of electric gear from them and it has a xicoy controller, he has have allways problems with this gear, any one has done any improvment on Controller or Retract motors??? can an Electron Motor be fitted????
Old 07-30-2023, 10:57 AM
  #666
NICKELUP
My Feedback: (82)
Hi everyone, I wanted to get your opinion on the original early version kits with Matrix gears. There is a older new never flown early version kit with matrix gears available here locally, and i wanted to know your experiences with the reliability of the gears, Does it retract without any constant issues? I don't mind shimming a little or cut any scale pieces to make them work, more concerned on the design of the unit, especially since i don't think i can get any more parts for it.
I have a few modelers telling me that they are problematic. Thank you in advance
