New Sport Jet: T-One Models Fortune
#176
CG measurements
Hi, just got a T1.
Read i3dm's recommended CG.
So, the CG is measures with the landing retracts up or down?
Apologies, just wanna make sure I get the CG right.
Best regards,
Vin
Best regards,
Vin
Fortune Jet - CG and control throws.
Ive had many people ask me to check my CG and throws, so i finally put the Fortune on the Xicoy CG meter.
This is with everything loaded, UAT full and main tank empty.
The CG which the meter is reading (90mm in front of main wheels with springs retracted) equals about 260mm back from leading edge wing joint.
I hope you guys benefit from there numbers, as you can see she flys just fine
Control throws:
Flaps: takeoff 40mm, landing 97mm.
Ailerons: 31mm up, 20mm down, 40% expo.
Elevators: 33mm up, 28mm down, expo 40%.
Rudder: 60mm, 40% expo.
Control throws:
#177
Tone
#178
