Starting problems rabbit 100 >
Old 05-13-2016 | 05:51 AM
Default Starting problems rabbit 100
I started up my rabbit for the 1st last night, and after the 3-4 step it shut down ..... And it was reading Idol ERROR???? Was this something I did wrong when I paired up my transmitter? If so how can I fix it?
Old 05-13-2016 | 10:32 AM
RCISFUN's Avatar
My Feedback: (44)
Welcome to the Jet Central family, Jet Central has a specific form that they monitor on a regular basis for posting questions that you may want to consider
Old 05-13-2016 | 10:34 AM
RCISFUN's Avatar
My Feedback: (44)
Not sure what you mean about 3-4 step?
Are you talking about Preheat stage to Switchover?
Is this a new Rabbit ?
Which electronics does it have? Powerpak SP or Powerpak SE
Did you review the manual?
If you need to talk to someone directly from Jet Central you can call the US rep:
Jose Melendez
231 Anthony Ave SE
Palm Bay Florida 32909
321-412-3078
[email protected]
Old 05-13-2016 | 11:58 AM
rcjets12's Avatar
My Feedback: (21)
hello,
please se give me a call and I will be more than happy to go over the settings with you.
Jose
321-412-3078
Old 05-13-2016 | 01:02 PM
Hello Baldhead
"To Idle Error" means that turbine is not getting to idle on a pre programed time
To avoid that you only need to increase the fuel a little
Go to Start menue and increase the initial fuel a couple of points and one point in the fuel ramp
That should solve the problem
Regards
Old 05-13-2016 | 01:12 PM
RCISFUN's Avatar
My Feedback: (44)
Great response from the team!
Old 05-14-2016 | 03:38 AM
Originally Posted by jetmon
Hello Baldhead
Regards
Thanks Juan!!!!!! Now it reads ACCELERATION ERROR as I go full throttle ?
Old 05-16-2016 | 05:37 AM
Hello
Please do the auto calibration procedure:
Start the turbine and leave it at idle until you get the "Min Pump Ok" message
Go slowly to full throttle and leave it there until get "Max Pump Ok" and you are done
If you need more detailed information of these procedure please refer to the manual
We recommend to do this procedure every time that you recharge batteries or if change something in your airplane fuel system
Regards
Old 05-16-2016 | 06:14 AM
Thanks !!!!!!! But I spoke with Jose Saturday, and Sunday was my maiden!!!!!! Went well!!!!! Very pleased !!!!!!!!
