Reload this Page >
All New KingTech EPO Jets, by HSD
Old 08-08-2017, 06:03 PM
  #376
afterburner
My Feedback: (18)
afterburner's Avatar
Originally Posted by oukenfold
I have seen this video and my f16 it's half that speed at full throttle
https://youtu.be/tBcM_32poFQ
Just curious what your altitude is where you are flying in Mexico?
Old 11-26-2017, 04:25 AM
  #377
PHUC1
Hello
I have got one kit of HSD F16 1800 MM foam.
please advise if I can use K85-G2 KINGTECH turbin engine or not? is it too heavy? how to adjust gravity balance?
Old 11-26-2017, 09:48 AM
  #378
extra 300
Hi
The K85 has the same weight of the K60 therefore no change in CG. However the 85 will burn more fuel than the 60 and you should definitely be cautious and use wise throttle management in order not to over stress the F16 beyond its limits
Regards,
Old 11-26-2017, 05:25 PM
  #379
Desertlakesflying
My Feedback: (28)
Originally Posted by luge_racer
Fine. How about: all HSD jets I've owned regardless of the power plant; whether turbine or EDF, stock or upgraded, have had glue adhesion and landing gear issues.
Well we would, but it is kinda hard to take you seriously after you conveniently left out the 100 class turbine part while bashing a company. Sooooooooo
Old 11-28-2017, 11:33 AM
  #380
BlueBus320
My Feedback: (57)
Originally Posted by PHUC1
Hello
I think top end on the K85 is too powerful for level flight, & not sure how the residual thrust will affect your landing speed although I think that the 16 will slow just fine. I can say that the HSD 16 does very nice high alpha flight, but with my K-60 Ive had some hairy moments transitioning back to forward flight at low altitudes. I will probably upgrade my P-60 in the future, but I already have my timer set to 3:30. I moved it up to 4min, but had no reserves for go arounds.
Jay
Old 02-07-2018, 11:49 AM
  #381
sharam
sharam's Avatar
Does anyone know where I can get a 2000cc fuel tank for the F-16?
The tank in the plane is only 1400cc and does not provide a long enough flight time for me.
Thx in advance.
Old 03-20-2018, 01:07 PM
  #382
sharam
sharam's Avatar
I installed a 2 liter coke bottle as a new fuel tank (earlier post on this thread) and combined with a k85 and careful throttle management, this is an awesome aircraft to fly. Flight time is easily 7 minutes.
Old 03-20-2018, 01:20 PM
  #383
afterburner
My Feedback: (18)
Nice! Did it require a lot of material removal or modifications to get it to fit?
Old 03-20-2018, 01:32 PM
  #384
sharam
sharam's Avatar
No removal, perfect fit. Had to epoxy the strap to the foam on the bottom - the lower neck on the bottle is perfect for the strap to hold the tank firmly in place.
I had to buy a bottle cap vent and fuel line attachment (Chief Aircraft) and quite surprisingly, it all came together with little effort. I made sure that I got the tank as close to the turbine as possible so that there would be minimal CG shift as fuel is burned off. My CG is around 175, far forward of the manual. I always measure CG in the landing configuration, landing gear down, header tank full, main tank empty.
I hit 145 mph on the telemetry GPS (tiny headwind) in a straight line at about 5/8 throttle. I am sure that if I pushed it at full throttle for a longer period, I would have confetti on my hands. A straight up line was just awesome and never ending. Power to weight is above 1.
The K85 (G2) is about the same size as the old K60 and it weighs about the same. I needed no weight in the nose; using a 2200 3S Lipo, 1300 3S Lipo, and a 2100 3S LiFe (turbine), upfront, brought the CG to where I wanted.
Old 03-20-2018, 02:01 PM
  #385
afterburner
My Feedback: (18)
Thanks for the info. May have to look into that after I maiden mine.
Old 03-21-2018, 03:58 AM
  #386
extra 300
Sharam,
Very useful info. Thanks for sharing. Did you notice any particular drawback from the added fuel weight on take off and during first couple of minutes into the flight? are you able to land the F-16 slow?
Regards,
Old 03-21-2018, 11:53 AM
  #387
sharam
sharam's Avatar
Originally Posted by extra 300
Sharam,
Regards,
The takeoff rollout was somewhat longer but once she was airborne, I really could not tell a difference in flight. I am still landing pretty fast; need to practice a bit more. My other problem was visibility. The camo works too well and on a partly cloudy day, she hides quite nicely. I need to get used to it up there.
Another mod I would like to make is to add baffles in the large tank to prevent all that fuel from sloshing around. While I noticed nothing in flight, I think baffles would be a good idea.
Old 03-21-2018, 06:42 PM
  #388
flejter1
flejter1's Avatar
Hi Guys,
I read about your modifications and want to throw my .02 in. This jet was designed around a 60N turbine or 12 lbs of thrust. You are now putting almost 60% more thrust in this jet with a K85 at 19lbs. If you want to increase the weight, wing loading and thrust, I strongly suggest changing all the Servo's. control rods, control horns and servo arms to a good heavy duty product. The servo's and hardware that comes with the jet is not the highest quality. The plastic servo arms and control horns are very brittle and breaks very easy under high stress. With the added weight, thrust, speed and flying forces, you will have a failure if you don't make other changes!! Trust me, I am all about having fun, but spend the extra time, effort and some money and change out all the hardware and servo's to give yourself a 1/2 of chance to get more than a few flights before it turns itself into coffee cups.
If you want to save yourself some heart ache, T-One has a 1.8M, Full Composite/Carbon Fiber F-16 coming out in a month or so. There are no control horns or control rods on any of the surfaces to deal with, as they built this like the 1/5 F-16 Big brother and has direct drive servo arm to control surfaces. This plane is designed for the 70-85N turbine but it has been tested with a 100N turbine to the most extreme flying to fully test its strength and durability. It has Electric retracts standard, light kit available as well as a PNP version. We will have pricing and more details out very soon.
Be Safe guys!!
Dirk
Pacific RC Jets
Old 03-22-2018, 11:40 AM
  #389
sharam
sharam's Avatar
Well, there is no increase in weight going from the K60 to the K85 G2; the two engines weigh about the same. There is some extra weight due to the extra fuel in the 2 liter coke bottle mod. The K60 seems underpowered. The K70 G2 seems ideal for this jet. The K85 is overpowered but quite fine with careful throttle management, and I would agree that the 100 is way overboard. The F-16 version I have (bought in January), has metal gear servos, metal horns, and beefy metal ball helicopter style links that came standard. If you use a K85 and go full bore the whole time, most likely you will turn the jet into confetti. Even with a K60, the jet will snap its wings if you go hard up elevator after a full dive. As with anything in this hobby, one can push the envelope with careful planning.
Old 03-22-2018, 04:52 PM
  #390
Desertlakesflying
My Feedback: (28)
The PowerHD servos, if they are still using the same ones, will be fine.
Old 03-26-2018, 12:26 PM
  #391
BusdriverSA
Hi All,
Been a while since I posted here. Asked this question over at RCGroups and haven't had too much feedback, save for one comment.
Does anyone know of any failures that have occurred, or any quality issues with the thrust pipes that are used in the HSD turbine F-16?
Busy converting a Yellow Aircraft F-16 to turbine power with a K-85 turbine and I'm looking for a pipe. Given that these jets are almost exactly the same size, this pipe should suit my needs. Any opinions appreciated, thanks.
Cheers,
BusdriverSA
Old 07-24-2018, 01:28 PM
  #392
Desert Fox 1
Hello All,
Although Pacific RC Jets no longer carries HSD products, They are available at www.HSDGO.com (HSD Jets)and www.bananahobby.com. Video is of my 111 flight of my KingTech K-60G2 powered Super Viper V3 in the T-45 paint scheme.
Cheers!
Desert Fox 1
Old 07-25-2018, 12:22 AM
  #393
jet-lover
Originally Posted by Desert Fox 1
Hello All,
http://youtu.be/PZ3CenxtOKY
Cheers!
Desert Fox 1
I am looking a getting one of these. Have you been happy with it? Would you buy another one today?
Old 07-25-2018, 04:52 AM
  #394
Desert Fox 1
jet-lover,
I have been very happy with my purchase. The Super Viper is a good first turbine aircraft. I have over 111 flights, with no real issues, yes I would buy another. I do not use the smoke system. I have plumb the to tanks together and have my timer set for seven minutes. I usually land with the main tank more than half full at seven minutes of flying. Top speed is in the 135-145 mph straight and level and 155-185 mph on gentle pull out of dives. These are from my telemetry readings. I got my turbine waiver with this bird. I am fly without the gyro turned on and find the aircraft stable and locked in. Unless you can find a sweet used deal, this is great way to get started in turbines. I fly at a very active club "Georgia Jets". Numerous members have commented on how well this aircraft performs. My RC aircraft YouTube channel https://www.youtube.com/user/rmshump..._as=subscriber
Cheers!
Desert Fox 1
Old 12-14-2020, 12:36 PM
  #395
CaptRKO
CaptRKO's Avatar
Originally Posted by Digital Pilot
Have a look at part one of this guys video, at about 9:00 he explains about the turbine placement and that it need to move back from what the factory says.. Dirk actually says 3/4 on the spacing.
Im putting one together with a KINGTECH 85 G4. Dirk said 1". I am going to verify. Can someone post pics of the installation if the pump, ECU, RX placement? I would appreciate that.
Old 12-14-2020, 07:48 PM
  #396
Desertlakesflying
My Feedback: (28)
3/4" from the end of the pipe to the tailcone of the turbine is standard for turbines
