Turbine Glider for 100-140N
My Feedback: (51)
Hello guys,
im looking for a composite turbine glider for 100N-140N size turbines, that can fit inside a Toyota Auris Station.
was looking at the CARF DG-808 which seems to have great performance but not sure if it will fit the car.
any reommendations would be welcome, looking for ARF or RTF if someone is selling something.
Any recommendations?
thanks.
thanks.
My Feedback: (39)
Depends on what you want. The Carf DG is definitely a good choice, but due to its size not very aerobatic or fast. I have just recently acquired a Swift S1 3.2m made by X-Models in Italy ( see http://www.x-models.it or http://www.facebook.com/xmodelshop ) . Due to the smaller wing span and the "double carbon" wing version I expect this to be more nimble and very aerobatic.
Thomas
Thomas
Bluelevel if it is your opinion that the CARF DG is not fast or aerobatic, I would have to ask have you even seen one? I have flown the pure glider version of the original airframe that Carf developed their model from. Unless CARF have radically changed their version, it was as fast as any scale glider as I have ever flown. I have been flying gliders for 45 years so I know something of this subject. It is all carbon construct and to compare it to anything from Xmodels is somewhat surpising.
I3dm if you need a smaller glider to fit in a small car then you really need to be thinking about a smaller turbine. Jet flyers regularly think too big in the engine department when it comes to powering a glider. So a 140 will be quite adequate for the Paritech 1/2 scale Fox. And a 100 would be more than adequate for the DG600 or any other 6 metre composite machines.
You really need to consider airframe strength. Gliders are generally not intended to be powered at the levels we jet modellers often apply.
Gliders are very low drag so need very little power to drive them forward.
You may want to look here:http://www.jettstreamuk.co.uk/fw-models.html
The Swift may fit the bill for size. The ASH 32 would suit a 100 or a 140 (with a little care). These are fast because they have very slippy wing sections and are all carbon construction.
Reagards,
John
Reagards,
John
My Feedback: (39)
@JohnMac
yes, I have seen the original Schaumburg DG-800 as well as the turbine powered Carf version and I have flown everything from a 6m Alpina down to F5B Hotliners or F5D Pylon planes myself. I have owned more than 15 different Carf planes and I do love them, but I prefer a nimble glider that flies almost like a jet over a scale glider with an auxiliary engine. A 6m glider like the DG-800 is too draggy and simply cannot retain the energy as good as a smaller plane. It is also sluggish when it comes to aerobatics. These are simple physics that cannot be denied.
I agree with you that the Carf DG-800 is a fantastic airplane, but after seeing the OPs videos and the airframes he usually flies, I am pretty certain that the Carf is not what he wants, hence my suggestion.
Thomas
Thomas
