Jeti Voltage Regulator SBEC 30 5-8.4V/30A (2-16S) EX w/Telemetry & Tx Programming
The new Jeti Voltage Regulator SBEC 30 D 5-8.4V/30A (2-16S) EX w/Telemetry
& Expander is here.
Brand new Jeti SBEC 30 D EX (2-16S) switching
regulator with telemetry gives you exact data about your servos regarding your
on-board radio system current (A) and power (mAh) consumption. The SBEC 30 D EX
also can help you indirectly identify possible servo problems (max current
increase) and give you the opportunity to resolve any issues before a possible
catastrophic failure. Another advantage of having live on-board telemetry is the
ability to fine tune the setup of multiple servo surfaces as out of sync servos
will fight each other and increase current consumption.
Select output voltage using Transmitter Devices Explorer: 5-8.4V adjustable in 0.1V steps
Modelers using different radio systems can also directly benefit
from Jeti SBEC 30 D EX using standalone telemetry with a JetiBox Profi and one
of the R4US, R5US, R6US, R7-9-11US, R14-18US receivers for current and capacity
telemetry data.
http://www.espritmodel.com/jeti-volt...-expander.aspx
https://www.youtube.com/watch?v=rDBhE0TIti4
& Expander is here.
telemetry data.
