Reload this Page >
New Y/A F/A-18 Hornet Build
Old 01-15-2017, 10:49 PM
Shaun Evans
Shaun Evans's Avatar
Howdy,
Got some work done on the bird this week. Got the bulkheads prepped for installation, including the little guide-block for your allen wrench (to tighten/loosen the plug-in fins). Milestone One: Getting all of the major bulkheads in. With the inlet taped in place, I poured the West System mixed with micro-balloons to form the inlet lip joint (as I usually do), but this time, it kicked off way faster than normal and got really hot. Luckily, my wife had a plant mister and I was able to hose it down and 'steam' the heat away. I plan to cut out the control surfaces and cap them tomorrow.
ID:	2196925   Click image for larger version
ID:	2196926   Click image for larger version
ID:	2196927   Click image for larger version
Old 01-20-2017, 09:15 PM
Shaun Evans
Howdy,
Plugging along. Cut the wing surfaces off and capped them with the precut 3/8" balsa sticks. Before that, I added some 1/8" ply in the areas I plan to install the scale bottom hinges by using a hot wire to make a slot, then epoxied them in. This was in the flap/aileron side only (and not the wing) because the hinge will tie into the rear spar anyway. Tomorrow, I'll glue the wings onto the spars. That's the 'don't screw it up' step of all steps.
ID:	2197578   Click image for larger version
ID:	2197579   Click image for larger version
ID:	2197580   Click image for larger version
ID:	2197581   Click image for larger version
ID:	2197582   Click image for larger version
Old 01-22-2017, 06:05 AM
tp777fo
My Feedback: (28)
tp777fo's Avatar
I need a SAN layover so we can have a beer again. Been too long my friend. Good to see you back in the building business.
Old 01-22-2017, 06:23 AM
TED ANTON
My Feedback: (7)
TED ANTON's Avatar
Keep plugging away buddy looking good
Ted
Old 01-22-2017, 09:25 AM
Shaun Evans
Indeed, Tom!
This time, the drinks are on me.
  #31
Shaun Evans
Ted
Thanks, Ted!
Old 01-22-2017, 07:13 PM
  #32
Shaun Evans
Hi,
Some of the steps in this build are tedious (at best). With the stabs, you have to glue the titanium shaft into a block of hard balsa. The anti-rotation pin goes into a little groove you cut into the balsa. In the older kits, you glued this block into the cutout in the stab and then sanded it to shape. With the last iteration kit, there's carbon cloth under the balsa sheeting, so you've got to carve the block into shape first. I shave these way down so I can easily fine tune their dihedral to match the wings when I epoxy them into the pocket in the stab.
Like I said, all the carving/shaping of stuff before it gets glued in can be a PITA, but I still prefer it to the uncertainty of some of the composite wings/stabs out there. In some of those old threads where people were posting those jaw-dropping x-ray photos of what lay beneath the skin on some of the 'less reputable' ARF's out there, the cautionary tale was clear. With these 'old-school' techniques, you're working harder to get the plane built, but you know exactly what's going on under the skin AND you know that if you want to get the stab pivots or the wing spars to come apart, you pretty much have to crash it.
ID:	2197779   Click image for larger version
ID:	2197780   Click image for larger version
Old 01-23-2017, 02:04 AM
  #33
blackcat
Yeah Shaun there some tedious bits but just remember what you end up with !
Old 01-23-2017, 05:10 AM
  #34
Shaun Evans
For real!
Old 01-23-2017, 01:43 PM
  #35
fly4food18
My Feedback: (15)
Subscribed. I am just love the F-18.
Good luck with your build. I'll be silently watching.
Brian
Old 01-24-2017, 04:42 PM
  #36
Shaun Evans
Thanks, Brian!
There are some parts of the plane I wish were composite (after all the sanding). Somehow, the balsa stab tips in this kit ended up being rock-hard balsa, but the sheeting on the foam stab is pretty soft. It's a tad trickier sanding the tips to the skin without going through the skin's depth too much. There's a slot in the aft corner of the balsa tip for a 1/32" plywood stiffener. Later, I'll finish sand the stabs and fins (once the spars/spar blocks are glued in).
You're supposed to make a little angle gauge for the fins so you can insure the fins are in at exactly 108.5 degrees.
ID:	2198067   Click image for larger version
ID:	2198068   Click image for larger version
ID:	2198069   Click image for larger version
ID:	2198070   Click image for larger version
Old 01-25-2017, 08:04 AM
  #37
Craig B.
Hi Shaun,
keep the the pics coming...great to see. I have an untouched kit here that I will get to one day, and the arf version, plus the zero and spit!
Old 01-25-2017, 09:09 AM
  #38
Shaun Evans
Craid,
I'll take that ARF off your hands whenever you want.
Old 01-25-2017, 08:49 PM
  #39
Craig B.
Haha, yeah ...not likely to happen!
Old 01-26-2017, 08:36 AM
  #40
Shaun Evans
Hi,
I got the fins mounted to their spars, which is a critical step because if you misalign them even a little, they'll be a PITA (if not nearly impossible) to take off and put on. I got the removable rudders hinged, but won't glue the hinges or guide-tubes in until after I've glassed everything. The rudder hardware is pretty neat. Not everybody liked it, but I never understood why.
ID:	2198266   Click image for larger version
ID:	2198267   Click image for larger version
Old 01-28-2017, 04:43 PM
  #41
Shaun Evans
Howdy,
So, I tackled a somewhat critical step in gluing the spars into the wings. I made sure my table was straight and level (it's a commandeered stage prop from the musical "RENT") then had to shim up the fuse a bit to get it dead-level measured from the table to the wing root at the TE. I used hysol in the slots, but really took my time getting the slots totally filled and as bubble-free as possible. The lightening holes in the spars themselves are even filled. Once that was done I measured the tips shimmed them up until they're equal with the proper anhedral and taped everything up to cure. Once that's done, I can glue the stabs onto their pivot blocks and use the wings as anhedral reference points.
ID:	2198651   Click image for larger version
ID:	2198652   Click image for larger version
Old 01-28-2017, 07:06 PM
  #42
Joe Westrich
My Feedback: (95)
Joe Westrich's Avatar
Makes me want to get back on mine.
I like build threads.....wish there were more of them
Old 01-28-2017, 07:45 PM
  #43
smchale
My Feedback: (67)
smchale's Avatar
+1
+1
Old 01-29-2017, 08:28 AM
  #44
Shaun Evans
Joe,
Why don't you? And start posting it here, too?
Smchale,
Ok, now I'm all self-conscious knowing you're looking
Old 01-29-2017, 05:53 PM
  #45
Kelly Rohrbach
Gluing,sanding,fitting,shaping,measuring,ie building, who knew. build threads are fun, an unfortunate missing component of our hobby these days.
Old 01-30-2017, 04:25 PM
  #46
Shaun Evans
+1
To keep myself motivated and plugging along, I've got some old (VHS) Jet Rally tapes from the 90's and early 2000's going in my shop. One from '96 had 100 jets and I couldn't identify any of them as ARF's. It's amazing how far things have come since then because you also see a lot of wire gear on stock Spring-Air units, but the guys in the videos all built there own planes from kits
Old 01-31-2017, 06:40 AM
  #47
Shaun Evans
Hi,
I've now got all of the flight surfaces capped and base-sanded except for the stabs. After gluing the pivot blocks into the stabs with slow-curing epoxy (so you can line the stabs up with the wings and make sure the anhedral is equal and the wings are parallel with the stabs), I'll cap those and do my best to get the root of the stab to contour perfectly with the fuse where it meets. After painting, the goal is to have only a paper-thin gap between the stab and the fuse.
Maybe I can get Sean McHale to show me the best way to mate the base of the wings and stabs to the fuselage to get rid of the steps and such
ID:	2199125   Click image for larger version
ID:	2199126   Click image for larger version
ID:	2199127   Click image for larger version
Old 01-31-2017, 08:13 AM
  #48
Airforce7
My Feedback: (31)
Airforce7's Avatar
Hi Shaun,
Would you happen to have any templates or an extra set of the wood mounting parts for a twin turbine setup?
Ken
Old 01-31-2017, 08:33 AM
  #49
Shaun Evans
Hi,
I think I've got a set of the wood engine mount parts for twin DF. Depending on your engine, they might be the parts you need.
Old 01-31-2017, 08:02 PM
  #50
smchale
My Feedback: (67)
smchale's Avatar
haha. Grab a cup of coffee and watch this video. It's a bit long winded but i wanted to keep a lot of it in real time so people could get the sense of how long the steps take.
https://youtu.be/fBRGklYklOI
i need some acting lessons. :-)
keep up the good work with the build!
