Reload this Page >
Florida Jets Photos
Florida Jets Photos
Old 03-17-2017, 07:26 AM
  #76
Dave Wilshere
I presumed he closed the throttle still holding the rudder. Anyway, too much guessing-sad loss and never great at an event
Old 03-17-2017, 08:25 AM
  #77
lavi rider
Shouldn't be a problem flying the hornet on a single engine , being the engines so close to one another .... lots of tail volume to compensate asymmetric flight . Flew the mig 29 on one engine and the tomcat too ... no issues at all ..
the way I see it he lost control over one controll surface and was fighting to hold her steady ..
very sad indeed .
Old 03-17-2017, 08:46 AM
  #78
TJP
My Feedback: (24)
Was this the only one of the new large Skymaster F-18's at FL jets?
Old 03-17-2017, 09:42 AM
  #79
FenderBean
FenderBean's Avatar
I know of two other large F-18s at the event, Jims got the F model in a Blueangles scheme and another fella did the maiden on his, i think it was the C model.
Old 03-17-2017, 09:47 AM
  #80
mr_matt
My Feedback: (10)
mr_matt's Avatar
Originally Posted by MNModels
Source close say asymmetrical flight..so lost one engine......sorry about your lost....
All of that from an engine out? Is the thrust angle weird on that model? What turbines were installed?
Sorry to see it go down.
Old 03-17-2017, 11:19 AM
  #81
David Gladwin
David Gladwin's Avatar
Sad to see someone lose a jet after an engine failure.
I recently had a flameout on my FC Mig 29 at the most critical time, just after take off, gear down, and brought it home safely using the same technique as on the full size Canberra, a pig on one engine, a *****cat on two.
I wrote it up on RCJI in the hope it might others to avoid an asymmetric loss, usually avoidable.
Basically minimal thrust, opposite RUDDER and keep speed as high as possible, the F18 with centreline thrust should be recoverable.
David.
Old 03-17-2017, 12:15 PM
  #82
philjac94
philjac94's Avatar
David.
Forever a gentleman Dave, "*****cat" is nowhere near as bad as the words the owner would have used (Edited) Sorry....RCU autocorrects *****cat here I was thinking you not wanting to offend
Regarding thrustlines on twins, On my 2m SM A10 I was particularly worried of an asymmetric condition especially after deciding on using 2 x VT80 engines (most others used 60N engines) and so I spent a fair amount of time setting up engines to give minimal change in yaw...it looked pretty dodgey but it seemed to work ok.
The forward fuse/nosegear only just held off the ground by supporting nylon chord, each main strut anchored back and a spring tied between more nylon chord and strut, main wheels on ground. Under power both springs would stretch out then when I idled down one engine at a time if it would shift in yaw, I adjusted the higher running engine in or out until I got minimal change. You do have to reference the theoretical thrust line through the fuse as the jet will still move about as the spring tension changes but where it settled was pretty close to a neutral thrust line. Quite surprising how much a little shimming is needed to correct a bad thrustline.
Phil
Old 03-17-2017, 12:41 PM
  #83
TJP
My Feedback: (24)
This is from 'gunradds' assembly thread. Been watching with interest to buy one.
Describes his first test flight:
"After doing a few more circuits with it in trim I was feeling pretty good with it. I know wanted to get it all trimmed out with the flaps/slats down and gear down. So I dropped the gear first and not long after that I got a real bad roll to the right. I fought this roll through the turn and realized I had an engine out. So I never dropped the flaps due to wanting to keep her clean. Even on 1 engine the plane had plenty of power just a real bad yaw/ roll to the right. Brought her around for landing. On our feild we have a big tree line to clear before dropping into landing. I didnt want to drop the flaps until I cleared the tree line. So on final I started dropping the power and as expected she rolled back to the left. Got her lined up past the trees and started to drop the flaps and slats but felt I had to add allot of up elevator and got scared of running out so brought the flaps back up for landing just to get her down."
Old 03-17-2017, 01:17 PM
  #84
FenderBean
FenderBean's Avatar
Well I know after this he went back and changed the the offset of the engines from a 3 degree to 1 degree. With the engines so close to each other you would think this jet would fly great with one.
Old 03-17-2017, 03:01 PM
  #85
mr_matt
My Feedback: (10)
mr_matt's Avatar
Was the gear down at 2:06?
Old 03-17-2017, 03:05 PM
  #86
mr_matt
My Feedback: (10)
mr_matt's Avatar
Phil
Yes these thrust lines must have an influence, I can't tell you how many single engine Mibo A-10 flights I have seen, but it appears many of the Skymaster engine outs end badly. With what would appear to be a similar aircraft
Old 03-17-2017, 03:28 PM
  #87
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Silly me for reading the title of this thread and assuming there might be pictures instead of Facebook bashing lol.
Old 03-17-2017, 06:36 PM
  #88
BarracudaHockey
BarracudaHockey's Avatar
I dumped another batch on the Fly RC Facebook feed.
Old 03-17-2017, 07:14 PM
  #89
TJP
My Feedback: (24)
Can't read the note on what looks like a Yellow F-18 Blue Angels.
Is it for sale and how much??
Thanks, Tom
Old 03-17-2017, 07:30 PM
  #90
newshoundaussie
Any where else to see coverage, usually a lot more info around on the net?
Old 03-17-2017, 08:01 PM
  #91
mikes68charger
My Feedback: (34)
Thanks, Tom
8k with Rino. If I remember. Landing gear was very sweet
Old 03-17-2017, 08:04 PM
  #92
mikes68charger
My Feedback: (34)
Takes to long to load photos
Old 03-17-2017, 08:11 PM
  #93
dubd
dubd's Avatar
Tons of photos and videos on Facebook from pilots, spectators, and manufacturers.
Horizon Hobby's Gallery: https://www.facebook.com/pg/HorizonH...54673629643935
Old 03-17-2017, 08:45 PM
  #94
marquisvns
marquisvns's Avatar
https://youtu.be/03bgIY3lQzs
T3 formation with T1, all KingTechs https://youtu.be/03bgIY3lQzs
Old 03-18-2017, 12:16 AM
  #95
lavi rider
The thrust tubes angle need changing ...
Old 03-18-2017, 02:45 AM
  #96
olnico
olnico's Avatar
At 0:53 the plane yaws 30 degrees to the right, then pitches up and snap stalls to the right, ending inverted.
I think that this maneuver is key to the problem that happened on this flight. I would be the owner of the plane, I would enquire this point of the flight first.
This 30 degree yaw to the right does not seem to have been commanded, nor the following pitch up input.
I would have a look at the control link as well as there seem to be quite a few uncommanded inputs on that flight ( unless the pilot was relatively inexperienced and very nervous ).
Old 03-18-2017, 03:29 AM
  #97
lavi rider
Hence my suggestion of not having a flameout but rather loosing a control surface
Old 03-18-2017, 04:25 AM
  #98
Eaglepilot2
Eaglepilot2's Avatar
Any video or photos of the B2 flying?
Old 03-18-2017, 05:24 AM
  #99
jonkoppisch
My Feedback: (162)
jonkoppisch's Avatar
Friend posted this on facebook
https://www.facebook.com/andy.woerne...70487322985109
Old 03-18-2017, 05:43 AM
  #100
dubd
dubd's Avatar
Video of the B2 flying: https://www.facebook.com/carfmodels/...54608509618983
