Reload this Page >
mig 15 1/4 scale composite
Old 08-13-2017, 06:14 AM
  #76
Mugu
Originally Posted by jcterrettaz
You so good , incredible work..of art
thank you!😊
Old 08-19-2017, 08:58 PM
  #77
Mugu
work in progress with first fuselage !
ID:	2228587   Click image for larger version
ID:	2228588   Click image for larger version
Old 08-23-2017, 06:01 AM
  #78
Mugu
mig 15
ID:	2229140   Click image for larger version
ID:	2229141   Click image for larger version
ID:	2229142   Click image for larger version
ID:	2229143   Click image for larger version
ID:	2229144   Click image for larger version
ID:	2229145   Click image for larger version
Old 08-23-2017, 06:56 AM
  #79
kimhey
Looking very good indeed!
Old 08-23-2017, 08:13 AM
  #80
Mugu
thank you !
Old 08-23-2017, 09:36 PM
  #81
Mugu
first fuselage 3200 g !😊
ID:	2229247   Click image for larger version
ID:	2229248   Click image for larger version
ID:	2229249   Click image for larger version
ID:	2229250   Click image for larger version
ID:	2229251   Click image for larger version
ID:	2229252   Click image for larger version
ID:	2229253   Click image for larger version
Old 08-23-2017, 10:28 PM
  #82
Mugu
ID:	2229258   Click image for larger version
Old 08-23-2017, 10:34 PM
  #83
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
well done!
How much forward you will be placing the engine?
Old 08-23-2017, 10:37 PM
  #84
Mugu
Originally Posted by DelGatoGrande
well done!
thanks ! you can see in photo the Engine mount
Old 08-24-2017, 01:02 AM
  #85
DelGatoGrande
My Feedback: (23)
I guessed it when i see your wing tubes that you will be placing it in the rear.
This is how the first generation CARF Mig-15 had the engine...it makes very big problem in balancing.
It needed more than 3kg in nose to balance correct . Maybe you would like to do a google search about it...it was big problem
http://www.rcuniverse.com/forum/rc-j...-cg-again.html
http://www.rcuniverse.com/forum/rc-j...-released.html
http://www.rcuniverse.com/forum/rc-j...-mig-15-a.html
They changed the design and move engine forward:
http://carf-models.com/files/product/18/2b/e0/12.jpg
MiG-15 Fagot 1:5
" The turbine has been moved forward by considerable 30 cm (12"). This gurantees that less balance lead is required to obtain the correct CG. ."
Now many owners including me we are moving even more forward the engine to eliminate the use of balancing lead.
I flew some Mig15's and the ones with this modification fly 100% better..lighter and less stress to the landing gear..
I can send you photos of the engine frames i made if u r interesting .
Again congratulations to your amazing skills and mig!
Old 08-24-2017, 01:18 AM
  #86
Mugu
MiG-15 Fagot 1:5
Attachment 2229264
Attachment 2229265
and you tubes from the wings how go in the fuselage ?
i will fly like this now and i will see how much balancing need in nouse ,next ones i will change for good balancing😊.thank you
Old 08-24-2017, 05:37 AM
  #87
DelGatoGrande
My Feedback: (23)
Here is my design for the CARF MIG-15.
Maybe one day i will brake out the frond frame and make new following the - - - - - - - - - - lines.
For two reasons. It allows room for bigger turbine like p160 ,the ideal engine for the CARF size as the p100 cant loop it.
It allows room to raise the engine to have "neutral thrust" as the normal mounting gives "up thrust".
Old 08-24-2017, 05:42 AM
  #88
DelGatoGrande
My Feedback: (23)
made out of multiple sheets of 3mm ply
Closing the pocket.Its oversized as seen in the draw to give room for alingment .In there you put the fibreglass tubes u have already made and fill all pocket with epoxy
Old 08-24-2017, 05:59 AM
  #89
Mugu
Attachment 2229276
Attachment 2229277
Attachment 2229278
thank you ! 😊 i'm very curios how will fly this bird .
Old 08-24-2017, 06:02 AM
  #90
DelGatoGrande
My Feedback: (23)
last photo is the carbon wing tubes... if you ever need to make this modification ,it would be good to cut a small line across the the tube so the air can come out while you inserting it.
Or while resin is still fresh you risk to pump air in the pocket when inserting or vacuum resin in the fibreglass tube while you remove it.
sorry for the poor english ..good luck!
Old 08-24-2017, 06:03 AM
  #91
gapellegrini
Mugu the Flytechnique Mig have the turbine forward than yours and need some lead on the nose. About 300g.
Old 08-24-2017, 06:10 AM
  #92
Mugu
aha 👍
Old 08-24-2017, 06:13 AM
  #93
gapellegrini
You will need a lot more than 300. Flytechnique turbine is 12 inches ahead than yours.
Old 08-24-2017, 06:15 AM
  #94
Mugu
i think 600 or more ! 😬
  #95
Mugu
after i fly the prototipe i will make changes
Old 08-24-2017, 06:17 AM
  #96
DelGatoGrande
My Feedback: (23)
I have fly quite a few jet models .I guaranty your. mig will fly absolutely amazing .The wing is just huge.
Just keep it light and use a p160 engine.
You might want to look also the last frame supporting the fin that goes all the way in fuselage.
http://carf-models.com/files/product...uctions_v2.pdf
and here is internal wing support of carf as suggestion
goodluck
Old 08-24-2017, 09:20 AM
  #97
Mugu
Attachment 2229284
goodluck
thank you ,is helping me this photo with structures!
Old 08-24-2017, 09:21 AM
  #98
Mugu
i love my mig 😍😎
ID:	2229291   Click image for larger version
Old 08-24-2017, 12:49 PM
  #99
DelGatoGrande
My Feedback: (23)
wow.. just realised how big it is ! It will be able to fly veeery slow!
...160 engine minimum i would say ..
Old 08-24-2017, 03:07 PM
  #100
sirrom
i love my mig 😍😎
I just got to say...that is BAD *****!
