Jeti Data Logging and Data Display, Useful or Useless? >
Old 06-14-2017 | 06:47 AM
ZB
Default Jeti Data Logging and Data Display, Useful or Useless? Now w/Video
Recently we have gotten many questions about how data logging and the capability to immediately display data on your transmitter screen post flight can help you become a better pilot. There are many areas where the Jeti system answers all your questions giving you detailed information about performance of individual components that could explain, improve or even prevent a catastrophe. We have to remember that the Jeti Transmitter is a scientific instrument and in our hands it will become the indispensable tool which helps us with improving performance, enjoyment, and safety of our hobby.
Jeti systems enable you to display, modify, delete, zoom in/out, and compare sets of data at any time without using the computer. All of this happens in your hands at the field. Once you finish your flight you will be holding all the answers to your questions in your hands. The Jeti System displays the activated alarms and all telemetry data right in front of you.
ID:	2220056 Click image for larger version
ID:	2220057 Click image for larger version
Old 06-14-2017 | 06:50 AM
ZB
Live Equipment Test
Rx A1Antenna Signal Strength Am I getting 9, should I relocate antenna?
Rx A2Antenna Signal Strength Am I getting 9, should I relocate antenna?
Rx QSignal Quality Am I getting 100%, should I relocate the receiver?
ID:	2220059Click image for larger version
ID:	2220060Click image for larger version
Old 06-14-2017 | 06:51 AM
ZB
Live System Optimization
Mezon Battery Amp (A) How many Amps is system pulling with current propeller?
Mezon Battery Voltage (V) How is battery voltage holding in correlation to the load?
Motor RPM What is the correlation between battery voltage and RPM?
ID:	2220062Click image for larger version
ID:	2220063Click image for larger version
Old 06-14-2017 | 06:54 AM
ZB
Post Flight Evaluation
SBEC Current (A) Are the servos overloading the Rx or BEC?
ESC Temperature Increases over time, Am I overheating the ESC?
Motor Temperature Increases over time, Am I overheating the Motor?
ID:	2220065Click image for larger version
ID:	2220066Click image for larger version
Old 06-14-2017 | 06:56 AM
ZB
Post-Crash Diagnostics (Unfortunately in Happens)
Rx A1Antenna Signal Strength Did we lose any of the antennas, were they shielded or damaged?
Rx QSignal Quality Was the 2.4Ghz spectrum clear, any interference?
SBECOutput Voltage Did we lose power over the flight?
ID:	2220068Click image for larger version
ID:	2220069Click image for larger version
Old 06-14-2017 | 07:23 AM
CraigG's Avatar
My Feedback: (40)
Is this display information available on all Jeti transmitters or only the DS/DC-24?
Old 06-14-2017 | 08:08 AM
I use a DS-16 and use the data log after EVERY flight to check my batteries and antennas. Also, I check my air pressures for trends if I am using more or less during retraction, extension, and braking.
Old 06-14-2017 | 09:26 AM
ZB
All, Jeti DS/DC-14/16/24
Old 06-15-2017 | 03:13 AM
Dr Honda's Avatar
on the 14... you pay for it as an upgrade. Its standard on the 16 and up.
Old 06-15-2017 | 10:38 PM
cycross's Avatar
What I will wish to see, is the ability to grab the last known GPS location of the last flight on screen again after I power down the Transmitter, assuming I have a mGPS on board the plane. I don't want to carry a notebook to download the telemetry file and translate it in order to do so (which is what it is today).
This can be a real life saver to find a plane lost in the woods.
Currently GPS lat long cannot be displayed as a playback.
Old 06-16-2017 | 06:46 AM
ZB
Only screenshot can do that, just do not power anything down. Or like I did, take picture with your phone.
I am sure somebody can make custom LUA script for GPS location, new Jeti DS/DC-24 can display whole map on the screen.
Zb
