CARF Mephisto Build thread
JTFDEZ (05-11-2023)
flyer1966 (09-04-2023)
#1083
Changing out my Spektrum/cortex set up to a competition SR2 on the atom.
What sort of current draw is everyone seeing with the mephisto turned on in standby?
Mine seems to fluctuate between 1.4-1.8amp on the display.
#1086
Okay so nothing to worry about then.
I have JR 8911 on all surfaces, in take off flap position this was my reading 1.4-1.8amps.
I have herd of folks setting alarms for too much amp draw whilst in flight, what sort of numbers would you recommend for a warning?
Also, since I have swapped out the cortex for the igyro sat what sort of gain figures is everyone using on:
Flight surfaces
Vector/3D mode?
Also using the gps 3
Flight surfaces
Vector/3D mode?
#1087
Have you read the figure with the wings off…and then with the back end disconnected? Because it’s not an acceptable figure for 8911’s which are super low draw at idle.
Futaba servos are known to be very high draw, then Savox and MKS. But JR Propo servos are very low. New MacGregor 8555 one of the lowest ever!
#1088
Thanks for your input Dave
This Mephisto has 75 flights on it previously using spectrum, so never saw the amp draw until moving over to powerbox. Ran a Y lead on the tailerons previously, now using the auto matching feature on the competition.
Rear fuse disconnected I'm getting 0.9-1.3 amps
Rear fuse and ailerons disconnected fluctuates from 1-2amps
Only flaps disconnected 1.1-1.8amps
Only tailerons disconnected 1-1.5amps
#1089
Why not start with just the electronics connected (and no servos) and see what the base current draw is. Then add just one servo at a time and see if there are any that are higher than average.
I'm guessing with around 10 servos in the model you're only pulling in the order of 100mA per servo at rest.
Paul
Paul
#1090
Those figures don’t make sense to me!
#1091
If you use a PB. Servo Bridge, one can evaluate individual servo loads in flight using the telemetry.
…..and, of course with the Competition SR2 you can measure total current consumption, really useful data !
#1095
6 years ago today the thread starter was test flown at my local club, I’ve managed to fly it each year nearest the date, but today is the exact anniversary. Weather is really not good with 30+mph wind gusts forecast, tradition is tradition, so I went and had two flights. No official photographer was available…so even the slowest flying and knife-edging machine available should have allowed Garry to get some decent shots…Mmm not really!
I must try to get the larger pipe fitted in 2024, I’m still flying the original pipe and ducting on a JetCat P-250 Pro and it smothers it somewhat.
Still a brilliant, reliable aeroplane.
AEROSHELDON (12-23-2023)
#1097
Elevators
Hello.
I'm almost ready for the maiden on my Mephisto V2.
All I need is to set center on my elevators.
Wonder if anyone can post a pic of their elevators at centerpoint?
#1099
Hi guys,
I have a question regarding the satin/matte finish on the Neon cayman scheme.
How is the paint holding up?
Does a satin/Matte paint require any special care?
How does the visibility compare to the gloss finish.
If given an option would you rather opt for a matte or gloss finish on the next one?
N
N
